Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Sandisk cruzer titanium 4 g
Hello , Just wondering if anyone can help . I used my girlfriends laptop the other day and used my cruzer usb ,she looged me on under her name and then I plugged the usb in . After that my screen saver came up etc and everything was fine . I ejected the cruzer ,and she shut the laptop down ,that evening she turned the laptop on and my screen saver was still there , and she could not get onto any of here files or could not log onto the internet or anything ,she could only log on as a guest but that will not give her access to her files etc . She had somebody look at it and they said it was the cruzers fault and she needed to put it back on and re disconnect it . However we cant even do that now ,and she cant even format the hard drive everything is blocked . Can anyone offer any suggestions has the laptop been attacked by a virus or something . Thanks.
    Problem Solver:
  • 6 Answers
Hi there. Don't think the cruzer has to do with the problem. You should have disconnect the device after finishing the job, many people disconnect the device directly without click on the icon showing the device was connected and then shut the device before doing the disconnect. To know what has caused the blocking, you have to go to "event viewer", under control panel -> admin tools and find out there what really happened. To do this first of all yo have to log as administrator, let's do it! Start your laptop, and just after wellcome screen press F8 before "Windows XP" shows it's loading. If you have been quick enough a menu will show up. Well done! Choose "safe mode" to load, you will be carried to a logging screen. Log as administrator, and then go to event viewer as I said. Look there if a program caused the issue (I've seen it many times) and then uninstall it (you always can load it later, do you?). If you have done all of this you can try now exit and log back normally. 2 possibilities: - All went fine. Cool! Stop reading, we're over. - Nope, still blocked. Go to safe mode again and create a second account to log in with admin permission. Microsoft knowledge base will instruct you to do so if you have any doubts, but it's quite easy. If finally you can log in with the new profile, then there's a way to copy data from a corrupted profile to the new one like nothing would have happened. In the knowledge base the doc id is 811151, or look for "how to copy data from a corrupt profile". The doc id sent is in spanish probably (which makes sense since I'm spaniard :-), not sure, but I'm sure you will not have problems to find the right doc in english. If all all this fails :-(, I'd suggest post the problem you've got on event viewer, this will lead to the solution almost for sure (Microsoft is not very good OS in my opinion, and prob log/debugging is not well developed, so can't be sure.) Good luck!
Posted on Aug 11, 2007
6ya staff
SOURCE:
SanDisk Titanium 8GB flash drive with files will not open
Microsoft has a fix for USB and other external peripherals.
http://support.microsoft.com/kb/925196#fixit4me
Hope this solves your issue. Good luck and all the best!
Greg
May 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Titanium 4gb NOT WORKING !!!
bad news bro, the disk isnt initialized. your data is long gone only a data lab may get them back
Mar 10, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Mac user with sandisk cruzer, no room & no way to format.
you guys have to empty the trash can or
1. open applications
2. open utilities
3. click on disk utility
4. locate the drive, left hand side
5. select the drive
6. click on erase
7. select file system, either MS-DOS or Mac OS extended.
have fun =D.
Jul 24, 2008 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
User manual download site for sandisk Cruzer Titanium USB 2.0 Flash Drive 8GB...in Spanish???
This information should be available for download off the SanDisk website. If there is no Manual in Spanish there, then it may not exist for download.
Try here (the SanDisk Site for Cruzer Titanium) first.
Apr 23, 2008 | Computers & Internet
USB device not recognized
corruption.
not fixable.
device can not tell os what it is. that is the most basic of functions.
without id, it can not set configuration needed to access data.
probably already lost data anyway.
replace is about the only option.
sorry for the news
good luck
mark
Dec 22, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk 1GB Cruzer Micro with U3/ Can't view files
Which antivirus are u using? U should update it. or Try with Norton or MCaffe antivirus.
other wise u can search for any hidden files exists in the drive. For this goto Tools then FolderOptions then View then check Show hidden files and folers and Search the virus name by using Start\search options
Dec 02, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk Cruzer Titanium 2.0 GB USB Flash Drive
It sounds like it is trying to use the E: drive and it is already in use? If so while you have the flash drive installed right click on my computer /click on manage / on the left side click on disk management / on the right side you should see the C: drive with other if you see the flash drive in this list with no drive letter right click on it / click on chang drive letter and give it a G: or other letter not in use. you will get a warning click ok and exit out your drive should appear. (note this is for windows xp)
Oct 13, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Cruzer Scandisk 2.0 titanium
Hi, Not unless you are using Windows98, your PC should automatically recognize the SanDisk Cruzer Titanium as a "Removable Storage/Device". Driver is not required for Windows ME, W2k or XP. If for some reason the SanDisk Cruzer Titanium (non-U3 devices) is not recognizable, then perhaps it is not a problem with the PC but with the SanDisk. Pls try all other USB ports of your PC (front and back). The SanDisk website provides utilities/software for this kind of eventuality. They are Sansa Firmware Updater and Sansa Connect Recovery Tool. Both are available at http://www.sandisk.com/Retail/DriverDownloads.aspx. Pls be forwarned that some utilities can and will reset your SanDisk to default and any or all data can and may be deleted. Hope this be of some help/idea. Pls post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Sandisk cruzer titanium 4.0 GB
May be the USB drive is damged. Try connecting it to another machine. If it works then plug it in to the same port as you have installed it.
Sep 03, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
388 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
