Question about Konica Minolta bizhub 180 All-In-One Printer
Aps size error (fls) - Konica Minolta bizhub 180 All-In-One Printer
"APS SIZE ERROR" in Develop ineo 231
paper size error check the draw guides the docfeeder guides and proper media system metric or inch
Apr 02, 2014 | Konica Minolta bizhub 180 All-In-One...
Axle size
Hi Anonymous, take a ride or drive over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary and offer professional advice and assistance concerning your issue. Have a nice day.
May 27, 2013 | Harley Davidson Motorcycles
Printing margin at left side on fls paper
did you check and clean primary transfer or change corona wire,optics , drum unit, or check the roller make program adjustment
Feb 20, 2013 | Panasonic Workio DP-3530 Copier
Printer comes up with (caution! aps size error) error message after i press the start button in the control to make copies.
1-Press "Tray" button or "Paper" button from the panel.
2-Select the paper size from the menu shown.
3-Now press the start button. No caution will appear.Next time use the same procedure for making copies.
Dec 28, 2010 | Konica Minolta bizhub 180 All-In-One...
How should i do photo copy of legal size
oh legal size you mean 8 1/2 x 14 in?
if that's what you mean, first we have to identify if your machine is set US standard. there you will be able to copy legal size. Otherwise if JP/EU standard, you can only copy 8 1/2 x 13 as the nearest size.
please check it first
if the sizes on the scree you see are A4, A5, A3, FLS, then your machine is set to JP/ EU standard. If you see LTR, INV, LGL, LDR, then your machine is set to US standard, and just select LGL for you to copy legal size.
that's it
May 20, 2010 | Panasonic DP-8016P Copier
My ploter is ready mode when printing giving error 0a0010-00000001 system error and not working model hp designjet 1050c pl resolve my issue
System Error: 0A0010
Problem
Description:
Problem in Pressurizing the Air System.
Corrective Action: Try the following:
n Replace ONE Ink Cartridge at a time, checking if the error code
disappears.
n Check all the cables of the APS and make sure they are correctly
connected and are NOT damaged.
n Check all the tubes of the APS and Tubes System and make sure
they are correctly connected and are NOT pinched or damaged.
n Faulty APS Sensor, APS Valve or APS Pump. Replace the
complete APS þ
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed
Oct 29, 2009 | HP DesignJet 1050c InkJet Printer
Aperture priority and image size
Auto and the other settings each have an independent image size that the camera remembers. You need to set the image size for AP. Go to AP mode and press FUNC. The image size should show up in the left menu (it may say L, M1, M2, S, standing for Large, Medium, and Small, resolution settings). Select it and choose a different size that you'd prefer (believe that you want L). Then press FUNC again to exit the menu.
Oct 11, 2008 | Canon PowerShot S3 IS Digital Camera
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Konica Minolta bizhub 180 All-In-One Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
