Question about GE Blenders
Blades are leaking on GE 169188 blender
I have a GE 169188 blender, and last night it started to leak around the blades and the plastic molding that holds the blades. Does anyone know where i can just the blades - or how i can fix it.
drumbanger
  • 1199 Answers
SOURCE: Can't separate blade unit from jar, but managed to make it leak
Soak in HOT water overnight and then remove! you may also have to replace the rubber seal inside to stop the leak!
Posted on Dec 31, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I have a Waring Pro Speciality Blender. After only
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Posted on Apr 01, 2009
SOURCE: GE Blender (169188) glass container: I broke the
I have a glass container...
Posted on Feb 24, 2010
espressonist
  • 1711 Answers
SOURCE: We have an old Waring Futura 900 blender that
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Posted on Aug 17, 2010
lindahb48
SOURCE: blender does not spin inside the plastic bowl
mine just broke as well the hand blener is working but the piece on top of the inside lide broke off so as not to make a good attachment with handle where can i geta lid
Posted on Oct 08, 2012
Leaking from around the base of the jug
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
How do i turn the bottom piece off the blender?
If it's like many other units, you can unscrew the bottom, BUT its a left-hand thread! (this is so as the blades spin colckwise, they don't unscrew the clear plastic body from the base if they trap stuff against the side).
Jun 04, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
Put it in hot water for a few minutes and then try to unscrew it.
Dec 31, 2008 | Blenders
Blenders Logo
61 people viewed this question
Top GE Blenders Experts
Pamela Leach
Pamela Leach
Are you a GE Blender Expert? Answer questions, earn points and help others
