Question about Friedrich D50C Dehumidifier
D50c the unit runs,however the bucket remains empty collecting no water.What should I do?
  • 2 more comments
  • pp1r May 29, 2008
    I have the same issue plus a bad smell from the unit
  • KARENA53 Jun 07, 2008
    D50C AND THE UNIT SEEMS TO RUN BUT NO WATER COLLECTS IN BUCKET AND THHE TOP OF THE UNIT FEELS HOT TO THE TOUCH
    THANKS FOR ANY HELP YOU CAN GIVE ME
  • YusufP Jun 11, 2008
    I have a same problem. I opened up the unit but don't see any frost on the coils. What else could be wrong?
  • lenahbo Jul 14, 2008
    The unit runs, but no water accumulates. It seems as if the fan is running but nothing else. The room temp is above 65, and there is no frost appearing on the coils. At least that would mean the unit is working but too cold. It runs, but I get nothing.
  • 525 Answers
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
I bought the FriedrichD50. It worked fine in 2 weeks with the built in pump. After I disconnected the drainage by using the bucket, no water comes out. Does it make sense the machine runs 2 days straight...
Yes, it does make sense, depending on what humidity extraction level you have it set on. Set to high, it will will remove little to low condensation/humidity. Set it to 35% or if you have an analog model (no LED screen) set the humidity extraction knob on Maximum Also, be sure that the air intake filter is clean.
Thanks for choosing FixYa.
Sep 19, 2011 | Friedrich D50C Dehumidifier
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Bucket full light comes on when the bucket is empty and it goes off.
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jul 30, 2011 | Friedrich D50C Dehumidifier
I just purchased this product and after running for 3 hours there is no water in the bucket. Why?
The unit often has cavities that need to fill before it goes into the bucket... also your humidity may not be that high...so you may not be getting much water out of the air...
heatman101
Apr 16, 2011 | Friedrich D50C Dehumidifier
Have had the unit on for 24 hours now & the water tank has remained empty all this time. Any ideas on this Amcor Dehumidifier dc100 ?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 21, 2011 | Amcor AHD65 Dehumidifier
My D50C friedrich dehumidifier does not work. It runs - but will not extract the humidity from the air. It has only been used approx. 2 summers - no more - because last summer could not even run it. It...
heatman101
Jan 20, 2011 | Friedrich D50C Dehumidifier
No water in basket
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 10, 2010 | Friedrich D50C Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Friedrich D50C Dehumidifier Logo
303 people viewed this question
Top Friedrich Dehumidifiers Experts
Bill Long
Gil Shultz
Marvin
Marvin
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
