Beko washing machine
My beko WM5554T stopped in the middle of the cycle, the door light stays on but the lights in the control panel are all switched off. I have replaced the door lock but that still doesn't help. Would it be the main controls that aren't working or maybe a fuse?
  • 209 Answers
SOURCE: Machine stopped mid cycle - door light illuminated
this appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Posted on Sep 18, 2007
  • 101 Answers
SOURCE: Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Posted on Apr 23, 2008
SOURCE: My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Posted on Aug 03, 2008
  • 6277 Answers
SOURCE: The washing machine will start
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 07, 2011
  • 66 Answers
SOURCE: beko wme8227 stuck half way through cycle
Ring ds suplies 01782-625551 and ask for chell
Posted on Aug 16, 2012
My whirlpool high energy washing machine style master #907675 just stopped working in the middle of the wash cycle. What can I do to get it to start working again?
not a good model # check on face of opening inside door frame.
door lock switch maybe your problem depending on model#
washer should show error code on electronic display by lights flashing or led read out if not lighting up can be control board check your home power first
Jul 03, 2016 | Whirlpool Washing Machines
Error F11 during the wash cycle
The error means that the controller is not talking to the other components. It is very expensive to repair,. If you want to run tests on it, there is a tech sheet behind the kick panel under the door.
Feb 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
Beko WMA10 W Washing machine. Power light on but thats it.
sounds like the main bearing,it would be cheaper to puchace a new mc
Jan 05, 2010 | Washing Machines
Beko WMA765s washing m/c 'dead'
Hi press and hold the start button for about 5 seconds .see if this works if not you will have a faulty pcb which will need to be replaced hope this helps
regards dan
Mar 19, 2009 | Washing Machines
Beko WMA 1715S
try unplugging and let it reset itself
Apr 03, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
