Question about Refrigerators
UC 148 A/Z
I CANNOT FIND SPARE PART FOR LOWER BOTTLE SHELF
Where can I get part #6 bottle rack for this unidentified refrigerator?
look on the manufacturer's website for parts available
Aug 25, 2015 | Refrigerators
Want to lower my dead key on my cobra 148 gtl mobile...where do i find the adjuster?
need to get a watt meter hooked up to then go the where the final is and look aroung for a tuning slug marked L38 and that is the baby you have to turn in order to power down this radio.
Nov 09, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
I have a very old wooden china cabinet that smells bad. How can I improve the small without keeping the glass open at all times?
My grandmother has the perfect method for getting the old woodsmell out of her china cabinet. First,you crumple up newspaper and put it between the plates for 24 hours. Supposedly, newspaper sucks up scent. The next day, place a water bottle cap filledwith vinegar on each shelf. After 24hours, the bad wood smell should be gone. To get rid of the vinegar smell, place a water bottle cap filled withvanilla extract on each shelf. Leavethat in there for 2 to 3 days and you should have a beautifully smelling chinacabinet!
May 29, 2012 | Furniture
Where can i get spare parts for iLuv i9200
Spare parts to this set can be bought from most of the electronic spare part selling shops at your town.
May 23, 2012 | Audio Players & Recorders
06 FORD E 250 HAS TROUBLE CODES 148 AND 191
I would check the fuel pump driver module. Silver box 3" x 2" mounted on frame cross member above spare tire. These modules have a tendency to corrode and crack allowing water inside. The result is erratic fuel pump operation and fuel related fault codes
Hope this helps
Apr 06, 2010 | 2004 Ford F150
Replacing brake light above trunk on 2006 chrysler
This is quite a process....
Removal
1) Disconnect and isolate the negative battery cable.
2) Remove the rear shelf trim panel.
3) Disconnect the CHMSL electrical connector (1).
4) Remove the two mounting fasteners (3) to the CHMSL (2).
Installation is opposite of removal.
Rear shelf trim panel
Removal
1) Disconnect and isolate the battery negative cable.
2) Remover the right and left lower and upper C-pillar trim.
3) Remove the nut that secures the center rear seat belt lower anchor to the stud on the floor panel and feed the seat belt webbing back through the opening in the top of the rear shelf panel trim (2) to the retractor.
4) Remove the push-pin fastener (1) that secures the trim (2) to the rear shelf panel.
5) Slide the trim forward to disengage the S-clip that secures the underside of the trim to the to the center of the shelf panel.
6) Remove the trim from the rear shelf panel.
Installation
1) Position the trim (2) onto the rear shelf panel(3).
2) Slide the rear edge of the trim rearward to engage the lens bezel of the center high-mounted stop lamp and far enough to engage the S-clip that secures the underside of the trim to the center of the shelf panel.
3) Install the push-pin fastener (1) that secures the trim to the rear shelf panel.
4) Pull the center rear seat belt lower anchor and belt webbing from the retractor through the opening the the top of the rear shelf panel trim and back down to the stud on the floor panel.
5) Install and tighten the nut that secures the seat belt lower anchor to the stud on the floor panel. Tighten the nut to 34 N m (25 ft. lbs.).
6) Reinstall the right and left upper and lower C-pillar trim.
7) Connect the battery negative cable.
C-pillar trim removal
Seat removal
Hope this all gets it done for you........
Feb 23, 2010 | 2006 Chrysler 300
How do I lower the spare tire without the factory 2004 Isuzu Asce
U need the special wrench to lower the spare, there is no other way since the cable hoist is under the spare tire.
Feb 03, 2010 | 2004 Isuzu Ascender
Spare parts needed!
WELCOME TO FIXYA TECHNICAL SUPPORT.
SURE I'LL HELP YOU.
IF NEEDED CONTACT US:
"MAKINO AUTO INDUSTRIES
D-146-148, Sector 63, Phase III
Noida 201 301, U.P. ( India)
Tel: + 91-120-2406985-86, 6519685-86, 4324049
Fax: + 91-120-2406987
Email: makino@makinoindia.com
Website: www.makinoindia.com
IS THERE ANYTHING ELSE YOU NEED TO ASK.
THANK YOU.
Nov 10, 2008 | kawasaki KR-1R Motorcycles
Refrigerators Logo
407 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
