Question about Dishwashers
Ecolab dishwasher The Second Tank stopped spraying out of the jets on the top and bottom the sprayers are hooked up right i have no idea where to look
jsrock516
  • 5911 Answers
SOURCE: maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Posted on Jul 31, 2007
Amigaman
  • 248 Answers
SOURCE: maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Posted on Nov 07, 2007
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
SOURCE: Kenmore 587 model dishwasher produces water but won't spray or move from bottom
top washer arm not turning
Posted on Sep 29, 2008
SOURCE: Bosch SKT 20 table top
Bosch SKT 20 επιτραπ?­ζιο νερ?? πλυντ?®ριο πι?¬των σταμ?¬τησε ζεστα?¯νεται, το βραχ?¯ονα ψεκασμο? ?­χει σταματ?®σει να περιστρ?­φεται και ψεκασμ??
Posted on May 23, 2010
I have a hotpoint HDA 3700 dishwasher that is about four or five years old. I has stopped rinsing thourghly, do you have a suggestion where I should start looking?
Make sure your water temperature is hot enough to dissolve the detergent, because the unrinsed residue could be undissolved detergent. If, however, it's food residue, you probably need to check your sprayer arms. The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer.
Jun 10, 2011 | Hotpoint 24 in. HDA3700G Built-in...
Bottom sprayer does not clean or work, all items on bottom are the same as put in. Top is fine. runs through whole cycle.2 hr 29 min
Check the free rotation of the spray arm. If arm jets are clogged clean them.
After placing the dishes see to it that, the arm is freely rotating without any obstacles.
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Fills, drains but does not spray water. I've made sure it is clean. no water comes out of the top and bpttom jets
Check for clog in chopper assy. This can be accessed by dissassembling the sprayer assy in the bottom of the washer. Chopper assy is replaceable part , if necessary, ~$25.
Mar 15, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
The pump has pressure applied, but no spry comes out.
These sprayers get rust in spray handle, they taking apart and lubing sprayer. If you leave chemicals in tank you will ruin the spray handle.
Jun 20, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Jet tech
Check with ECOLAB.COmpany all over the world
Mar 07, 2008 | Jet Tech Systems STEALTH Dishwasher
Maytag jet clean dishwasher model# dwc7400aaw
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Maytag jet clean model#dwc7400aaw
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
