Question about Snapper Garden
Briggs 6.75hp intek
Valve settings
3 Suggested Answers
SOURCE: i have a 17hp briggs and stratton vertical intek
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Posted on Apr 02, 2010
  • 35 Answers
SOURCE: 17.5 briggs intek backfiring thru carb wont start
Easy things to check, flywheel key, make sure it is not broken, check the coil gap to the flywheel. could be the coil is not advancing. Check, if it has one, the oil sensor by unplugging it. hope this helps.
Posted on Apr 14, 2010
What are the valve clearence settings for intake and exhaust on 20hp b/s #461707
.004"-.006" on intake and exhaust valves cold engine. I would set them at .005" .
Feb 16, 2017 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
VALVE ADJUSTMENT ON 13.5 HP BRIGGS AND STRATTON ENGINE
Need help I set the valves on my 13.5 Briggs and now it won't stay running unless I close off the airflow to the carburetor
Sep 20, 2010 | Parks Optical 13.5hp Briggs And Stratton...
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
Nov 22, 2009 | Briggs & Stratton Garden
15.5 intek pushrods whitch one is for the intake vavle ?
Intake is aluminum, exhaust is steel. Set valves 1/4" past top dead center on compression stroke (both valves closed), intake (bottom) .003-.005, exhaust .005-.007
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
B/S 23 H.P. OHV Hard to turn over.
THE VALVE NEED TO BE SET TO 3 TO 5 THOUSANTHS
Apr 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
44 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
