Sharp fo a660
I cant clear memory fax
5 Suggested Answers
  • 2072 Answers
SOURCE: Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Posted on Jan 10, 2008
SOURCE: Fax Memory....
To reset memory problem you turn power off, then you hold down star and stop key ,then you will see on the display three options press option number 1 clear
Posted on Jan 05, 2009
  • 186 Answers
SOURCE: sharp plain paper fax FO-A660 dialing but not
First test the phone line with a conventional telephone, make sure you have a dial tone. If you do make sure the phone cord from the wall is plugged into the correct port.
Posted on Apr 25, 2009
SOURCE: Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
Copies and fax reports are minized - only printing one half the document
Posted on Jan 15, 2010
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Memory full on a sharp FO-2081
Enter simulation mode using # * c * and then run test command
66-10 to clear image memory. This happends if you get a garbled fax from interference or noise. You should get a power filter with fax and network ports if it keeps happening.
Apr 03, 2014 | Sharp FO-2081 Copier
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp plain paper fax FO-A660 dialing but not sending fax
Apr 24, 2009 | Office Equipment & Supplies
Sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Jan 28, 2009 | Sharp FO 2950M Plain Paper Laser Fax
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO 5700 - Please Wait For A Moment message
Hold down the stop and start key while turning on the fax, let go when you see 1 for yes 2 for no for memory clear. Press 1.
Sep 08, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Fax Memory....
Jun 30, 2008 | Sharp FO-4400 Fax
20 people viewed this question
jasbo
jasbo
