Question about Music
Korg toneworks ax1500g
Lcd dim
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
I have a korg pa50sd, but its lcd brightness is too high..how to control this? it is very difficult to read?
There is no adjustment to control the brightness in korg pa50/sd.
It is hardware problem.
-Is the white backlight that is too high?
or
-normal backlight,but words is too dim?
Both of that case,can be caused by damage / change of voltage control for lcd. Perhaps there are parts that are damaged or have changed in value. Typically capacitors etc.
If the backlight is too bright, then the damage is in backlight controller, may transistor or an inverter transformer.
Proceed with the repairs to the experts.
Jul 08, 2015 | Korg Music
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
Korg Triton Studio LCD malfunction! Please need help badly! :(
Where can i purchasea lcd for my korg triton studio
May 28, 2012 | Music
Korg ax3000 g display not working
It is likely something internal. The LCD is backlit so there is a chance it may be something on the order of a bad connection at the power supply input. Possibly a broken wire- as long as unit was not dropped, using a multi meter to check power is a pretty straight forward way to proceed.
If it got wet, there is possibly a burned out pico fuse, or corrosion on a connector or contact area for the rubber conductors for the display.
If unit was dropped- You may want to contact Korg to see if the display board is available. It likely is not. Which means it is a time and or money investment.
Feb 12, 2012 | Korg Music
Want to replace my korg triton lcd touchscreen.where can i find a new one?
You will have to go to Korg to get the replacement screen.
Here: http://www.guitar-parts.com/catalog/korg/korg-touch-screens-lcds
Wow ... $300... ouch...!!!
Mar 30, 2011 | Music
CRACKED LCD ON A KORG TRITON EXTREME...
Try this link:http://www.korgparts.com/content/estore_list.asp?category=3&catname=Korg
Oct 19, 2010 | Music
I have a korg triton studio the lcd touch screen in the middle of screen blinking ,what problem have?
Touch screens can develop a problem of dirt getting under the edge causing triggering as if one is pressing there is only one of several possibilities.
Due to the value of the instrument, I would take this to a repair shop as you probably don't have resources necessary to repair the unit.
Feb 19, 2010 | Music
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
