Microsoft Windows XP Professional for PC Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Realated to starting of multiple operating system
When ever i install xp over vista i had to reinstall the fresh copy of vista again.is there any possible solution for this kind of problem.
Tim Nelson
Level 2:
  • Expert 83 Answers
  • Posted on Mar 16, 2009
Tim Nelson
Expert
Level 2:
Answers
83
Questions
11
Helped
26660
Points
239
No, because your going from a newer os to and older os, so microsoft wont allow you to have vista and then install xp and keep all the info. the only way to do it would be a dual boot option for xp and vista. just make another partition on your hard drive to install vista to.
How to restore Dell Dimension 8200 to original factory setting?
  1. Insert the Operating System CD into the CD or DVD drive.
Close any program or utility that may start to run after you insert the CD into the drive.
note.gif HINT: The CD that you need to place in your CD or DVD drive is titled Operating System.
  1. Turn off the computer, and then turn the computer on again.
  2. When the blue Dell logo appears, press immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down the computer and try again.
  1. Use the arrow keys to select the CD-ROM option, and then press .
  2. When the Windows XP Setup screen appears, press to select To set up Windows now.
  3. Read the information in the License Agreement window, and then press on your keyboard to agree with the license information.
  4. If your computer already has Windows XP installed and you want to recover your current Windows XP data, type r to select the repair option, and then go to step 15.
If you want to install a new copy of Windows XP, press to select the fresh copy option, and then press on the next screen to select the highlighted partition (recommended). Then follow the instructions on the screen.
The Windows XP Setup screen appears and Windows XP begins to copy files and install the devices. The computer automatically restarts multiple times before it requires additional input.
  1. When the Welcome to Microsoft screen appears, click the green arrow icon at the bottom of the screen to continue. Follow the on-screen directions to finish.
  2. When the Regional Settings screen appears, select the settings for your locale, and then click Next.
  3. Enter your name and organization in the Personalize Your Software screen, and then click Next.
  4. If you are reinstalling Windows XP Home Edition, enter a name for your computer when the Computer Namewindow appears, and then click Next.
If you are reinstalling Windows XP Professional, enter a name for your computer and a password when theComputer Name and Administrator Password window appears, and then click Next.
  1. If you have a modem installed and the Modem Dialing Information screen appears, enter the requested information, and then click Next.
  2. Enter the date, time, and time zone in the Date and Time Settings window, and then click Next.
  3. If you have a network card in your computer, select the appropriate network settings. If you do not have a network card, this option does not appear.
Windows XP begins to install its components and configure the computer. The computer automatically restarts.
  2. Remove the CD from the drive.
  3. Reinstall the appropriate drivers. See "Reinstalling Drivers."
  4. Reinstall your virus protection software.
1helpful
2answers
I loaded a fresh copy of window vista on my laptop and now i cant locate files
If you have installed a fresh copy of Vista and that was a new installation and not an UPGRADE, then you must have lost everything on the computer. You can try and locate a folder with your old user name OR a folder named Windows.Old. If you get any of these folders you can try and search your files over there.
Regards,
Shrey
2answers
How do i uninstall windows vista and making a clean dard drive
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
1helpful
2answers
My daughter (aged 12) has loaded a copy of Vista (which were discs from a computer her grandmother no longer owns and has been scrapped) onto her laptop which had Windows XP installed. She does not have a...
Hi.
If she did not format the hard disk, then the Windows XP startup option will be present in boot option. When computer startup you will get a choice like this:
1 Microsoft Windows Vista Home Edition.
2 Microsoft Windows XP Professional SP2
In that case you can restore XP, starting on XP and editing the file winboot.ini, that is an hidden system file located on C:/ drive.
See:How to edit the Boot.ini file in Windows XP.
If instead Windows XP does not start, or if you do not get the boot option, that means that Windows XP system file had been deleted.
In that case the only way to get back Windows XP is reinstalling the system from scrap, using a Windows XP install disk, and the number listed on the licence sticker.
Regards.
How to install vista 64 bit over 32 bit i installed my 32bit version i didn`t relize that it only supports 4gb minus my video card=3gigs total memory, so do i have to reinstall my 64bit as a fresh install...
Yes. But Vista is full of problems. I suggest you use XP instead. Some computer manufacturers now offer XP for a small surcharge because they recognize that Vista is a lousy Operating system.
6answers
HP 4215 not working at all
you need to install a driver compatable with vista.
Wish to dual boot vista home premium and windows xp
to achieve dual boot both XP and Vista, first u need to install xp and then vista on it as a fresh copy
Unable to Access Any Operating System
i would try to reinstall xp on the first and largest hard drive and go from there, reformat, and start from the begining. there should be no problem if you do this as long as you have a legit copy of xp and reformat.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
