Question about Dryers
Inglis ied4400sq0 WILL NOT START WHEN I PUSH THE START BUTTON. I HEAR A TICKING SOUND WHEN I MOVE THE DRYER TIMER DIAL TO AN ON POSITION.
Amigaman
  • 248 Answers
SOURCE: Kenmore 27 inch wide electric dryer
Can you turn drum by hand? If so you probably need a motor.
Posted on Nov 19, 2007
  • 142 Answers
SOURCE: Faulty Start Button?
If the dryer doesn't even start to turn when you press the start button, then you have to look at a couple things; The start button itself, the starting relay or the safety circuit. You mentioned that there's a ticking sound... if this sound goes away when you open the dryer door but comes back again when the door is closed, then the safety circuit is working.
It could be the switch itself or the starting relay (if equipped with one). If you're mechanically capable, consider looking at the relay. See if the contacts are being pulled in when the start switch is pressed (DANGER: HIGH VOLTAGE). If it is, the start switch is OK.
Hope this helps.
Posted on Apr 02, 2008
vanni7
  • 163 Answers
SOURCE: Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
Will not start but its making a ticking sound
Electric or gas dryer?
Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue.
If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm.
With more information, I may be of better assistance.
Feb 14, 2012 | Dryers
My Whirlpool Inglis Model IED4400SQ0 dryer just stopped. The fuse is fine. I think the problem might be in the start button but I'm not sure. I think this is it because the dryer stopped 2 days ago, then...
this doesn't have a board in it so you either have a bad timer or motor,i would think it would be the timer,try tapping on the timer with a screw driver or something light or wiggle the timer knob and see if it starts,also did you have this on timed dry?it sounds like the timer died and then somehow power went through it again and it ran,the timer controls how long the dryer will run so this is why i think it could be the timer,or a broken wire but try wiggling the knob and see if it starts.let me know thanks.
Dec 22, 2017 | Whirlpool Inglis IP8200 Dryer
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
If there is no voltage on any parts ,the timer contactor is faulty
Sep 19, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer light is on and can hear the ticking sound when you turn on the timer but it does not start when i push the start button
Thermal fuse is bad. If had model or brand could give part number but it is defenitly the thermal fuse. Hope this helps.
Jan 31, 2010 | Dryers
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Won't shut off
sounds like you have a bad start button.
Jun 02, 2009 | Dryers
Dryer Won't Start
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
