Question about Grilling
How do you calibrate a commercial restaurant gas flattop grill? The center reaches 550 degrees but the sides only reach 250 degrees
How long should I oven roast a 6.53 boneless pork shoulder roast and at what temperature
Cook at 250 for 4 hours and cover with foil , parchment or even news paper and cook at 250 until it reaches 187 degrees this will melt all fat and connective tissue. Total time will be about 6 to 8 hours.
Mar 02, 2016 | Grilling
Why can't you answer my question about thawed meat
How long was the meat out and did it reach a temp higher than 40 degrees. If so, some restaurants might call that a health code violation.
Jul 29, 2012 | Grilling
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
What temperature should my Weber 8006 heat up to ?
That, my friend depends on what flame height the burners are set on and how long the lid is closed. If left long enough, I suppose it could reach 550 to 600 degrees. Which is more than what's necessary to seer a steak. Why do you ask? Having a problem with the grill not heating well?
Apr 10, 2011 | Weber Grilling
I have a natural gas hookup and my grill takes a long time to heaat up (15 minutes) and max degrees is 350 - 375. I found dust in the connection hose blew ut out. Also took grill apart and cleaned...
Unfortunately, that's the way it does on Natural Gas, in an outdoor environment. The reason being, Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Of course, on the plus side, you don't have to get tanks refilled. With that said, the thermometer on the grill may be faulty.
To test this theory, buy an inexpensive oven thermometer (the kind that can be placed on an oven rack) and place inside the grill, when you're preheating it with the lid closed. Once you grill thermometer reaches 350 degrees, open the grill hood and compare it the two temperature readings. If the oven thermometer is reading significantly higher, then you no the grill thermometer is faulty.
Hope this helps you get back up to temperature.
Mar 02, 2011 | Weber SPIRIT E-210 (NG)
The grill only reaches 200 degrees
PROBLEM
Barbecue temperature only
reaches 250° to 300° in the HIGH
position.
CHECK
The excess flow safety device,
which is part of the barbecue to
cylinder connection, may have
activated.
CURE
To reset the excess flow safety
device turn all burner control knobs
and the cylinder valve OFF.
Disconnect the regulator from the
cylinder. Turn burner control knobs to
HIGH. Wait at least 1 minute. Turn
burner control knobs OFF. Reconnect
the regulator to the cylinder. Turn
cylinder valve on slowly. Refer to
“Lighting Instructions”.
http://www.weber.com/manuals
Sep 07, 2009 | Weber Genesis Silver B Grill
Smoker will not reach heat of 250 to 300 to effectively smoke meat
I have heard that the "new" propane tanks have a saftey valve that closes if they are opened too quickly, try opening the valve very slowly. When you say it has been cleaned that means you have checked the venturi and the burner for spiders?
Apr 12, 2009 | The Great Outdoors 3405BG
Low flame on 3 main burners. model GBC730W
Mike, I had this problem with my grill once or twice. Like most of us grilling men we turn the grill off at the tank trying to be safe. Sometimes, like in my case, I do not turn the nobs back to the off position. When returning to the grill the next day or week the first thing we do is turn the gas on leaving the nobs on, then lighting. Every time I do this my flame never gets full or does not reach full temp. To resolve this: turn everything off including the nobs, then turn the gas on, wait a minute or two. Turn the nobs to full and ignite. It should be at full flame then, adjust from there. I hope this is helpfull.
Sep 23, 2008 | Grilling
Grilling Logo
167 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
