LCD light seems. It doesn't work
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on May 07, 2013
MANY TIMES MY LCD DOESN'T ON AND AFTER SOME TIME ORANGE LIGHT COMES DOESN'T CHANGE TO GREEN FROM THE REMOTE OR LCD POWER BUTTONS. I AM FED UP FROM THIS THAT I GOES IN SLEEP OR OFF POSITION AUT
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 23, 2012 | Sony Bravia KDL-32BX320
Dropped kodak cx7530, lcd display doesn't work, lights up but no picture
see the video instructional and proceed with common sense and logically. God bless you
Aug 02, 2012 | Kodak EasyShare CX7530 Digital Camera
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Hi, i have a samsung b1930n monitor. It's menu
My monitor is getting blank within 3 seconds after I start my system what could be the problem
Jul 09, 2011 | Samsung Monitors/LCD LCD Panel
I can't get my float on my dehumidifier to work. It is in full mode although empty. The light keeps flashing.It doesn't seem to be making contact with the "switch" in the unit. Can you...
Just, gingerly jiggle the float ball rod and it should release and return to the down position.If that doesn't work the first time, spray a light coating of WD40 on it.
Jun 17, 2011 | Maytag M7DH45B2A Dehumidifier
Hp g60, power light comes on, wireless light is orange, charger works ok but wont power up
Hi kr 2583,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 11, 2011 | HP G60-230US Notebook
My LCD has seemed to stop working, I get brown lines and white squares.........is this fixable issue at home or need I send t sony?
If the LCD doesn't work at all, you can't see menus or play back old pictures then the LCD is damaged and needs to be replaced. Sounds like this is the case, it's about a $130 repair including the part, installation and return shipping of the camera. Hope this helps!
Thomas Drayton
Owner, www darntoothysam com Digital Camera Repair
Dec 13, 2010 | Sony Alpha 350 Digital SLR Digital Camera...
Computers & Internet Logo
David Payne
David Payne
