Question about Garden
Global 100956-010000 opener
I need to rep;ace the chain
Code p1150 had all 4 senors rep aced in my Toyota
If everything is ok then use a code reader to reset the CPU
Oct 30, 2013 | 2003 Toyota RAV4
Flapper stays open
Hi Tom
Try shorting the chain first,..if that does not work then buy a new longer chain to solve the problem
Bud
Apr 24, 2013 | Ace Hardware Eljer Toilet Tank Flush Lever
I need to add the chain oil and can't find the type or how much. I went to ace and they didn't know what it took. Do you?
Just use standard chain/bar oil available at home centers, hardware stores, and saw dealers. You were obviously dealing with unskilled help at the Ace store! Just top up the oil tank which should be refilled with every fuel fill-up. Nothing magic about this. Hope this helps!
Jan 31, 2011 | Garden
What type of chain and sproket does a 2000 Honda VT 750 Shadow Ace need?
The stock gearing is 17T sprocket front and rear is 41T sprocket. Chain size is a 525/122. Hope this helps you out
D.
Sep 29, 2010 | 2000 Honda VT 750 CD Shadow A.C.E. Deluxe
How and what kind of oil do I use on the chain on my 2002 Honda Shadow ACE 750?
there is a spray chain lube lube that you can buy from any motorcycle supply store, oil just goes everywhere, the special chain lube sticks to the chain and works much better and last 10 times as long.
May 28, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
I have a 1998 honda vt750 shadow ace and i need to know what the tooth count is on the rear sprockett and the chane size i need to get
only way to be sure is to count the teeth. most chains you buy are longer than need and you cut off the extra links.
Aug 11, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Is the final drive chain on a 2002 honda ace a 525-122 0-ring chain?
yes it is stock but does'nt absolutely have to be an o-ring chain to replace it
Jun 26, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Changin chain on 2002 honda shadow ace
Unless you are changing sprocket sizes you can not shorten the chain because removing even one link would not allow the ends to connect. Are you adjusting the chain as needed? Why do you want to shorten it?
Even if the factory chain has no master link (some are continuous these days) you can still grind off two pins carefully and push out a link to remove the chain, or simply cut it. That is what you must do when replacing the chain.
Apr 05, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Chain Size
Go to a web site like bikebandit.com and pick the make year and model of your bike to see the part diagrams. Find the drive chain page and it will usually tell the size of the chain.
Jan 14, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
