Question about Jeep 2006 Commander
Reset computer flashing panel
Gauges check on flashing panel
My cluster panel does not work its got lights no gas,heat,rpm,or speed gage don't work
Try pressing and holding the trip reset button with the key on. After about 10 seconds it should tart flashing all 1s on the odometer. It will cycle all the way to 9 and the gauges will do a dance that resets them. If that doesn't work then in all probability the gauge cluster has failed. Usually it's bad solder joints in the cluster. If you know someone who has experience soldering have them reflow all the solder joints. It's also possible the servos that actually move the needles have died or the computer that drives them died
Nov 20, 2016 | Cars & Trucks
How can the computer be reset?
Not everything a scan shows..dealrs usually dont hav the smarts. Computr is probly ok..the instrument panel is worn..napa has xchanges. Reseting computrs takes a factory scan tool..areflash or reprogramin is done to see if its stil gud
Dec 22, 2015 | 2008 Saturn Outlook
Problem w/gauges they will flash on while driving stop working then go back to normal.
problem could be in instrument panel circuit. a wire might be broke or melted on the circuit board. may have intermitting touch of broken wire causing gauges and lights to flash on an off.
Mar 31, 2015 | 2008 Ford Taurus SEL
What would mke my instrament panel flash all lights and make my speed omeder go way over to 120 and then back again while driving down the road
Sometimes able Battery can cause this.It would be a good idea to have system scanned for fault codes..If not,..First check battery voltage for no less than 12.40 to 12.60...disconnect battery to check for proper battery voltage....Disconnecting the battery will reset the vehicle computer system which may solve your problem however it is rare for your issue.....If nothing solves your problem you need an instrument cluster which attaches to the inside and connects behind the gauges...
Jan 27, 2015 | 2006 Dodge Caravan SE
97 BLAZER TRIP COMPUTER ISNT WORKING, KEEPS FLASHING
Disconnect battery...hard computer reset...should fix it. If it continues, it is the gauges.
Jan 17, 2015 | 1997 Chevrolet Blazer
How to reset DIC after battery went on 2004 GMC Sierra... no gauges work, or lights and ABS icon is on as also the battery icon...
Replacing a battery won't cause this unless you happen to hook it up wrong. In that case, check fuses, All of them. If they are all good, start replacing all those parts to include some computers.
Jan 08, 2015 | 2004 GMC Sierra
2004 kia optima odometer flashing
The gauges are computer controlled, if the system fails the gauses all stop. You need the dealer to scan this with the KIA tool.
Mar 20, 2014 | 2004 Kia Optima
My 1999 cherokee sport says ''no bus''. I have no gas gauge, speedometer, etc. I have already removed the instrument panel and thoroughly cleaned the terminals and plugs that connect to the back of the...
it is not the plugs.if you remove the printed circuit board,which is double sided,you will see that the solder joints on the back of the plugs where they are soldered have cracks in them.resolder the plugs.
Jul 11, 2009 | 1999 Jeep Cherokee
Jeep 2006 Commander Logo
15 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
