TIC TIC TIC noise durinf start up
During stsrt up there is a tic tic tic noise comming from the board.
ginko
  • 19396 Answers
SOURCE: Toshiba 24AF41 24" TV Problem
The tic tic sound is a device called safety switch that keeps turning your TV off because an internal fault, such as a defective component or a wrong voltage is detected.
When is like that we say the tv is in protected mode.
Start unplugging TV power cord for one or two hours (it is called hard reset), this will drain power from tv and seset internal circuit, and sometimes can clear the error message, if the fault was only temporary.
If the problem does not go, then you have to troubleshoot the problem, probably some component inside the tv is faulty and may need to be replaced. If you want to do it yourself is better to buy the service manual.
Here you can buy parts and service manual.
If you need to call for repair you can use the phone number listed on the TV owner manual.
Posted on Sep 17, 2008
  • 24 Answers
SOURCE: Sony Trinitron
Take it to an authorised repair agent. Sonys can be very complicated for both amateur and professional alike. I have spent hours on some of them.Most probably a failed voltage regulator though very common for Sonys and expensive.
Posted on Oct 08, 2008
  • 62 Answers
SOURCE: Acer CRT Monitor with tic tac sound
1. horizontel transistor bad.
2. dry points on neck board.
3. cheak the power supply out put
4. LOT problem
Posted on Oct 14, 2008
burzerko
  • 254 Answers
SOURCE: Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Posted on Nov 15, 2008
mie999s
  • 105 Answers
SOURCE: TV not coming on
try check the horizontal output or flyback transformer..on the pcb board..sometime lizard die stuck below the pcb and tv shock when you switch it on
Posted on Dec 08, 2008
Milwaukee 2792-20 M18 Jobsite charger/radio not working
sadly there is no help for things bought from Craigs list try contacting milwaukee thru their website
Aug 29, 2016 | Audio Players & Recorders
TV do not turn on and make a noise as tic tic tic
Main board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2015 | Panasonic VIERA Televison & Video
My Hampton Bay fan instlled on a slopped cielling on High speed I hear TIC TIC TIC when I rduce speed o MED no more TIC TIC what is the solution. Does the model 459-664 can it be installed on a sloppe
What do you expect to get from a store brand fan? They're cheaper because they use lower end parts. Always look for a fan with at least a 13 degree blade pitch for better air movement.
Mar 28, 2014 | Hampton Bay Dryers
Tic tic tic sound when switced on no sound no video
:That sound usually means the power supply cannot start--due to an overload or overvoltage problem. Likely a few bad capacitors in feedback area or some short in horiz. area, possibly convergence chips if a tube set.
Mar 22, 2014 | Televison & Video
For last 2 weeks, whenever I tried to open my PC (Clone PC), HDD became start to make a noise, Tik-Tik-Tik. Windows cannot be loaded. I tried with a bootable CD, but it also fails to load any Drive. I
The tic tic tic noise is known as the tic of death. This hard drive is faulty especially when you go into the BIOS and the hard disk is not detected. This is why when you try to install Windows it cannot detect a hard disk.
The hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jun 12, 2012 | Computers & Internet
When i start the car, it make a funy noice
i cant tell
is it noise like continuous ticking like tic tic tic tic
or a corrosive sound like chhhhhhhhhhhhhhh
or just engine revving high rpm
is it coming from underneath like muffler or exhaust system ?
describe locate diagnose fix just that simple sir .
Jun 06, 2011 | 1999 Volkswagen Beetle
Fridge not cooling and make tic tic noise
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dfafh
May 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I've got a problem!! When I drive backwards, I can hear very well a strange sound, it's like ''tic tic tic tic tic..'' it's just during driving backwards!?!? Where is the fault? Someone knows this problem?...
There are several possibilities. It can be the speedometer cable, the brakes, or even the u-joints on the driveshaft.
The parts rub against their mating surfaces differently in reverse. Any play or dryness in the parts shows up. Sometimes it is good to catch these problems early because the wear is starting to get excessive.
Aug 27, 2009 | 1990 Mercedes-Benz E-Class
Nov 02, 2008 | Ovens
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
