Maytag washer mtw5840tw
My washer is 5 years old and has begun making clickity clack noise at beginning of wash cycle. What's causing that?
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
  • 183 Answers
SOURCE: Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Posted on Jul 30, 2007
  • 686 Answers
SOURCE: My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Posted on Apr 06, 2009
scottowa
  • 87 Answers
SOURCE: grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
Posted on May 25, 2009
  • 3 Answers
SOURCE: maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Posted on Jan 08, 2011
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
Rumble/clacking while draining & spinning
Check for debris in filter of pump assembly. The filter unscrews out of the machine. It is located behind the bottom panel. Remove the two or three screws holding the panel in place, gently ply down and you will see what looks like a handle. It will be hard to turn but unscrew it and check to see if there is any debris. Have towels near by as there will be quit a bit of water coming out as you remove it. It the unit still makes noise there is a good chance the pump motor is going.
Feb 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer noise during spin cycle
remove the belt and spin the motor by hand to see if its noisy then the pump.if its the gearbox you would be better to replace the machine,i havent seen to many last more than 5 years the gear box could cost about 500.hope this helps.
Mar 26, 2008 | Washing Machines
Noisy Washer
Jul 25, 2007 | Maytag Performa PAV2200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
