I've had my Keurig plugged in but not turned on for about 1 month. Before I put it to ''sleep'' I gave it a thorough cleaning using the instructions given by Keurig (vinegar & rinse). Anyway, I went to use my P60 this morning and what a nightmare. None of the cup level buttons provide the correct amount of water anymore. If I push a small cup the brewer spits out some water then pauses and then starts going again and overfills the cup. On the Large cup level the brewer seems to be somewhat accurate but not like it used to be. The only way to stop this is to turn the machine off. When I do that, and turn it back on, water spits out into the cup and then it goes back to heating mode. Any ideas?
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket....
(More)
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
Water does not flow through Brew Central even after it has been cleaned. Our 12 cup Brew Central...
(More)
Water does not flow through Brew Central even after it has been cleaned. Our 12 cup Brew Central unit works fine for months at a time and then the self clean indicator lights up. When we clean it, the water just seems to disappear, it does not drip into the coffee pot and it is not in the water resevour.
