Question about Pool & Spa
Fix hurlcon vx salt chlorinator
The no flow and low salt wont light up and the mode button will not allow me to move from auto to standby mode
  • 297 Answers
SOURCE: I have an intex chlorinator and an intex 24' x 48
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Posted on Jul 09, 2009
  • 297 Answers
SOURCE: low salt indicator
high concentration? Salt is salt except for the fact in aq pool you want 98% pure and it must not be iodized salt
Also before generating salt with the timer you must have the right amount of salt
the #'s in the manual are just guidelines
get a salt test kit and get your pool to 3000ppm you need to filter only 24 hours or so getting to the 3000ppm wheather you ad salt or need to drain water and ad fresh none the less get it to 3000ppm
Now worry about your chlorine level if it is to high leave alone until it comes down if too low then run the generator for a few hours if it does not show on the scale at all try 4-6 hours
you will get a knack for the amount of time you need for your chlorine situation
if once all of this is set right and you still get high reading on salt unit take it apart as directed and spray it out with the garden hose
it is really simple only 4 screws
Posted on Jul 13, 2009
  • 128 Answers
SOURCE: High chlorine/cloudy/salt water pool
Purchase a PoolRx unit for your pool. PoolRx.com....No more algae!! Clearer water
Posted on Aug 30, 2009
ftw1952
  • 10319 Answers
SOURCE: I have the Intex Above
Shock the pool with 4 gallons of muratic acid if its a 28,000 gallon pool. Normally that would be a 26 foot wide by 4 feet deep
Posted on Aug 31, 2010
  • 297 Answers
SOURCE: We have a 15' by
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
The low salt light is on and is not making chlorine. Salt level topped up yesterday as per pool shop sample. Chlorinator stopped sometime yesterday
the salt light indicates more than low salt level. now that you have eliminated that possibility, if the light is still on, there may be several possible causes. the cell may be dirty, or nearing its end of life, there might be restricted water flow or the water is too cold. these are all easy and inexpensive to check
Mar 06, 2016 | Pool & Spa
Vx salt chlorinator has suddenly stopped working fully, when on manually it just stays in sanitising mode. Every thing is fine chemical wise and pool level but output of chlorine is not happening
look for corroded valving or white powdery residue thatgs got the piping/hardware plugged up..may need replaced if you cant brush it off..
Jan 06, 2014 | Pool & Spa
Zodiac lm3
The lm series chlorine generator has a tri-sensor inside the cell that measures flow, water temp, and salt level in pool. If the controller is indicating no flow after it has been cleaned properly, then the cell is most likely in need of replacement.
Jan 06, 2014 | Zodiac Lm3-24 Salt Water Chlorinator...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
My salt water pump keeps saying low salt. I have had the water checked and there is plenty of salt. I have cleaned the cell and it still says low salt. The pump is on;y 1 year old. I dont know what else to...
I suggest you clean the cell according to manual and try it then. If it keeps producing chlorine then keep swimming. If the pump is flowing water fully (if not clean baskets and filter) and it can't keep the chlorine above 2 ppm and you have 30 to 50 ppm stabilizer in the water then there is a major problem in the chlorinator. I don't trust the salt indicator on some chlorinators but that is less important than if it chlorinates. You can but salt test strips. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Im getting a blinking 93 and my water wont clear up.
93 is stand by mode indication of the cycle completed.. You may need to increase the cycle time.. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
I
Jul 24, 2011 | Intex Saltwater Chlorine Generator 2000...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
What is a code 93?
Code 93 = Good News for You! :-D It is your Saltwater Chlorinator's way of letting you know that it is working properly and your pool's water has a level of salt that is optimal/good.
Code 93 just lets you know it is not actively converting salt to chlorine...it is in 'standby mode.' When you first programmed the number of hours you wanted it to run (by pressing the left (down)arrow until you heard the beep, then pressing the right (up) arrow until you heard the beep - then pressing up until you reached the desired number of hours you wanted the unit to operate (minimum 1 hour, maximum 12 hours)) the unit began converting salt to chlorine immediately.
This is good news for you. Once the number of hours of operation are up, your unit will give you a code when you press either button. If your salt level is too low, you will receive code 91 indicating this, if your salt level is too high, you will receive code 92 indicating this, if the water flow is too low, you will receive code 90 indicating this (this gives you the opportunity to correct this before the next cycle begins. If there is no error with your pool's water, your unit will go into standby and wait until it is time to run the numbers of hours you programmed it for (it will begin it's cycle at the same time each day unless reprogrammed by you). When this happens, you will find code 93.
So, just to recap:
Code 93 = Good
Code 92= Salt level too HIGH (Empty approx. 20% of pools water & refill with fresh water.)
Code 91 = Salt level too LOW (Add salt.)
Code 90 = Low Water Flow (Check your filter. If it is working properly, you may find that it is too small for your pool. The filter that came with my pool was FAR TOO SMALL - I spent more time cleaning the pool than swimming in it. My 18' x 4' pool came with a 1500 filter. Now, I have a 4000 Sand Filter. This + the Saltwater Chlorinator = practically no maintenance. Together, these were approximately a $500 investment. WELL WORTH IT!!!)
Code 88 = Startup mode. (Press down arrow until you hear the beep. Press up arrow until you hear the beep. Press up arrow until you have the unit set to operate the number of hours you desire.)
As an extra FYI: The unit works with the sun. This means the unit turns the salt from your pool into natural chlorine which is then sent back into your pool. The sun turns this natural chlorine into salt. Your filter sends this salt into your saltwater chlorinator where it is again converted into natural chlorine & returned to your pool where then sun...I think you get it. ;-) It's a continuous process. ~This being the case, when you program your saltwater chlorinator, it is best to set it up to help it work with the sun rather than setting it up to compete with the sun. You do this by programming it to run at night. This way, your unit isn't working hard to generate chlorine at the same time the sun is diligently converting the chlorine to salt. I've read several articles where people argue that you should run your saltwater system at night & your filter during the day. I don't understand this concept. My filter runs 24/7 & my saltwater chlorinator runs 12 hours - from 8pm to 8am. Since I set my pool up to operate this way, I have not had to clean it at all other than backwashing the filter every other month just for principle. My water is crystal clear.
One further note of interest: My pool holds approximately 6000 gallons of water. For this, Intex recommends 135 pounds of salt. Because of some advice I'd read posted by other users, I started with only one 40lb bag. This was all my pool needed. Approximately once/year, I add one more 40lb bag.
RJBALLZER777, because you are receiving code 93, I realize you have set your pool up correctly and, therefore, are possibly thinking, "Why is she telling me all of these things I don't need to know?" I apologize if that is what you are thinking. I am really posting for those who have not gotten it just right the first time (or who are doing their research before buying as I did) so that they may get several questions answered at once. Hope you don't mind that I used your question as a means to post. (That's why I answered your question right off the bat.) Hope this post helps some.
Jun 20, 2011 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
