Question about Frigidaire FSC23F7D Side by Side Refrigerator
FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
THE ICE MAKER AND WATER DISPENSER WORKS FINE, BUT WHEN I PUSH THE LEVER TO DISPENSE THE ICE THE LIGHT COMES ON AND IT MAKES A CLICK SOUND AND A SLIGHT HUM BUT NO ICE WILL COME OUT. PLEASE HELP !
  • 1 more comment
  • ToddnJulie Dec 27, 2007
    We have the same problem on our FRS26HF7BW1 side by side and HAVE just replaced the auger motor. Still, no movement of auger motor. When you push the paddle, there is a click and the motor hums, but the auger will not turn. You can reach in and physically turn the auger motor, but it will not turn on it's own.
  • dogsitter May 03, 2008
    ice dispenser problem
  • bthomas1234 Jul 01, 2008
    Mine is a Frigidaire FRS26HF7BB2. Per comment "You should see the drive gear rotating on the back panel. If it is not rotating, this is your problem. " So the drive gear is not rotating for me and I want to relace this augur motor. Anyone have quick steps on replacing the augur motor? It looks like you disconnect the plastic clip power connector, remove 2 screws at the bottom of the augur 'housing' and remove this whole piece. Then begin taking off screws until you get to the auger motor. Does this sound about right?
    New Friend:
Have same or similar problem. MY problem turns out to be that the Auger turns fine, but there is a little metal blade that attaches to the end of the auger and transfers the spin action into this auger "hopper" (for lack of a better term) which actually accepts the ice that has been moved from the back of the ice bucket by the metal auger and then dispenses the ice into the hopper which falls into the glass. the issue is one of crappy design. It turns out that this little blade has a rectangular opening in the middle that the rectangular end of the auger fits into. If this rectangle opening gets stripped (as mine has done, and ALL are likely to do) then the auger spins, the ice is moved forward but none are picked up by the hopper, and none (or very few) fall into the glass.
Everyone should check to see if this is the case. If so you may need to order a new blade, or a new auger, or a new refrigerator.
Good Luck!
Posted on Jun 10, 2010
    President:
  • 331 Answers
Your auger or your auger drive is locked up. To test which, remove the ice bin from the freezer and set it aside. Now, with the door open, hold the light switch in and activate the ice dispenser on the door at the same time. You should see the drive gear rotating on the back panel. If it is not rotating, this is your problem. The auger drive motor and gear box is either frozen (can be thawed out) or locked up and failed (needs replacement). If the drive gear rotates, the problem is in the ice bin itself. Dump all the ice out of there and inspect the auger. Is it frozen? Locked up? Are there any broken pieces which have caused the auger to get out of alignment and become jammed?
Posted on Aug 11, 2007
    New Friend:
Problem is with a side by side frigidaire. It's blowing warm air. I took off cover to icemaker. I then put my screwdriver to one of the gears and turned it clockwise, about 1/2 way. I plugged the fridge back in and it immediately began to blow cold air. It worked great for about a month, and is now blowing only warm air, again. After hearing contradicting solutions from a few people...im puzzled. Will replacing the icemaker solve this problem??? thanks
Posted on Feb 12, 2010
We finally got it fixed! It took a few visits from a refrigerator repair company, but it had nothing to do with the auger/auger motor. After all the auger always moved freely when turned by hand. We also replaced the auger motor, with the same results, just a hum with no ice.
Finally, it was determined that a circuit board behind the control panel on the front of the freezer went bad. Call a repair guy, this isn't something you can troubleshoot and fix yourself.
Posted on Mar 04, 2008
I have this issue too. Its in the dispenser bin. The auger in the back moves fine, but its not turning up front and spitting out the cubes. Gonna pull it apart and see what is up.
Posted on Mar 03, 2008
2 Suggested Answers
SOURCE:
ebenezer
  • 25 Answers
SOURCE: frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Posted on Aug 10, 2007
The ice maker works perfectly in my Sears Kenmore Elite Refrigerator, but the ice crusher doe snot work. When i put the glass under or I push the lever, no ice comes out. I have removed all the ice sevral...
Push the lever to dispense ice and listen for a small click sound,(the micro switch). If you hear a click you will have to determine if there is a broken wire to the dispenser motor or if the motor itself is defective, This will not be a visual diagnosis unless you fine a broken wire in the hinge area.
Eric
Nov 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
Side by side Frigidaire. The water dispenser
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the tube.. You can take the water line off the valve and watch to see if it drips.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 30, 2009 | Refrigerators
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
7,505 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
