Question about Gaggia Platinum Vogue 90800 Espresso Machine
Gaggia platinum warning signs
Hi, My coffee machine has a flashing red light sign on the Left side of the strength button. Every coffee I make has too much water even though I have placed it for the short black.
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
Posted on Oct 10, 2007
SOURCE: PROBLEM WITH LOW FLOW/PRESSURE IN GAGGIA COFFEE DELUX COFFEE MAKER
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Posted on Aug 07, 2008
SOURCE: no crema on short black
Make sure the coffee is a fine grade...place holder in machine for 6 mins before filling with coffee and ensure the filter holes are clear and dry.
Posted on Oct 29, 2008
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
SOURCE: low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Posted on Sep 28, 2009
Gaggia unica red triangle flashing at same time as green cup
Hi there My experience tells me that when a red light flashes on a coffeemaker it is one of three things: It needs water to be able to make more coffee The "bowl" that the compressed coffee goes in ids full and needs emptying It needs cleaning I would start filling the waterholder, Then emptying the compressed coffee holder If neither works, then start the cleaning prosess Best of luck and enjoy your coffee Kolbrun
Sep 18, 2013 | Gaggia Brera Coffee Maker
Does anybody know how to get rid of flashing red exclamation light on my gaggia platinum vogue?
It does not need to be descaled as this is not the descaling indicator...The water circuit needs to be primed. Turn the knob to the water drop and drain water into a bowl. Hold the water drop button down while this is happening until the red light turns green. Presto.
Oct 07, 2011 | Gaggia Platinum Vogue 90800 Espresso...
Looking for an english manual for Gaggia Platinum Swing Up coffee machine.
Hi
I have the original manual (a bit marked) but a better solution is to download the manual for the Swing Model from http://nettopdf.info/download.html?dl=aHR0cDovL3d3dy5jaGV6YmV0dGF5LmNvbS9pbWFnZXMvZ2FnZ2lhL2dhZ2dpYSUyMHBsYXRpbnVtJTIwc3dpbmcucGRm&t=pdf&name=Gaggia%20Platinum%20Swing%20Operation
The only difference is the manual, instead of electrical mechanism that moves the cup(s) up and down.
Cheers
Liz
Oct 07, 2010 | Gaggia 90901 Platinum Swing Up Automatic...
I have a Gaggia classic. It won't turn on,no lights.
Hi
There are 2 things that it might be.
1. There is a high limit thermostat on the left bottom side of the boiler. Somew have a red button in the middle between the wire terminals. Push it it you have the red button.
2. There is a thermal fuse on top of the boiler. it is in a plastic cover that is clamped to the top. If it blows it has to be replaced.
Apr 11, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Red exclamation point is flashing rapidly. Usual
Descale machine, then you have to tell the machine that the descale has be done, by holding the hot water button for 6 seconds.
Nov 26, 2009 | Gaggia Platinum Vogue 90800 Espresso...
There seems to be a lot of water in the dump box.
The amount of water will vary with the strength of coffee selected.
On the front control under the cup symbol is 3 beans,pressing these will increase strength .
All bean lights on strong.
All details should be in the manual or available online.
Oct 21, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Red light on my machine
Hello Jennifer. It's nice to see a name. My name is Ned. I'm typing in Grsggia in the search bar to see what pops up. You may want to also.
Sep 27, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Platinum Vogue 90800 Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
