Oki c5750 fatal error 122 service call - Office Equipment & Supplies
5 Suggested Answers
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
  • 13 Answers
SOURCE: OKI C5900
Most likely you have paper wrapped around the fuser or at least stuck in the fusers sensor So remove anywhere you can see paper. If not it will need a replacement fusing unit.
Posted on May 01, 2009
  • 9 Answers
SOURCE: fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Posted on Jun 23, 2009
radar001
  • 1051 Answers
SOURCE: We just installed our Oki
Transfer paper has a tendency to leave residue not only on the roller but also on the drum and fuser. If the residue is minimal you may be able to clean it yourself with extreme care. The drum unit cannot be exposed to direct light for more than a few minutes before it's ruined. Examine it as best as possible, looking for spots of residue or scratch marks. If found clean with OKI recommended cleaner. The fuser has a built in cleaner which you can manually move to clean it. Use care as the fuser is delicate.
Since the C5650n is considered "over the hill" and will probably be discontinued soon you may as well go ahead and attempt the repair on your own.
Posted on Oct 22, 2010
Reset drum oki c5750
I am impressed with the analyses and the solution to drum reset Paul Lorentze gave but I don't know if it is also applicable to Oki C5750. If so, I will like to know where to connect those two electrical wires that will be demonstrated and act like a fuse. Kindly give me an urgent answer to this please.
May 16, 2012 | Office Equipment & Supplies
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
122 fatal error on c5500
Power Supply Fan Motor Error
When low-voltage PSU thermal error or a malfunction of fuser ventilation fan (PX713 only)/PSU cooling fan has been detected. Unplug the printer from the power source, wait one moniute, then plug unit back in and restart.
Seek attention of service person if restarting the printer does not correct the problem
Dec 08, 2009 | OKI C5500n Laser Printer
Fatal error 122 on a oki c5200 printer
Jun 23, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
119 people viewed this question
k24674
jasbo
jasbo
