Question about Garden
Mountfield sp530 spark plug and gap - Garden
4 Suggested Answers
SOURCE: Spark plug gap?
Without you!
Posted on Apr 13, 2009
huffman49
  • 235 Answers
SOURCE: spark plug type and gap for mountfield sp470 mower
CJ 6 plug with a .032 gap
Posted on Apr 04, 2010
  • 111 Answers
SOURCE: make mountfield empress 16
The gap is .020 for most applications. If you get a new spark plug it will come pre-gapped.
Posted on Apr 05, 2011
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Adjusting the carburettor springs on a mountfield sp530 to run correctly
most governor springs do have slack... they are designed to apply pressure during operation... the governor tries to run the engine wide open, the governor spring brings it back to a safe usable rpm... most small engines run well between 3200~3600 rpm's... I don't know what engine you have so I can't help more
Oct 20, 2014 | Garden
How to remove pullcord housing on mountfield sp530
if its a briggs and stratton engine you will need to remove the top plastic cover then take out the 3 bolts out of the starter cowl, 1 on the front, one on back left and one back right. the one back left may also have be securing the exhaust guard . the bolts are 3/3" (10mm) after the bolts have been removed you just lift up the cowl/starter assembly
Sep 07, 2014 | Garden
Make mountfield empress 16 please could you tell me what the required gap ison the spark plug is thank you .
Mar 23, 2011 | Garden
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
No spark on GV100 honda engine mountfield laser mower have fitted new coil
I assume you replace the coil due to the fact you didn't have any spark. If so, make sure you have the leg gap to flywheel correct. 12 thou should get you spark. However, if still no spark, check out the switch at the lower section of the cable. May only need an adjustment there, as the old cable do stretch with time and the gap is now incorrect. Make sure when you engage the cable that the switch isn't still grounded. Also, check the flywheel key to make sure it's not sheared off. Good luck
Oct 09, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
