Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Frigidaire ice dispenser problem
WHEN I PUSH THE LEVER ON THE ICE DISPENSER IT MAKES A CLICK AND A SLIGHT HUMMING NOISE BUT WILL NOT DISPENSE THE ICE. I TOOK THE ICE BIN OUT AND PUSHED THE LEVER AGAIN BUT THE PIECE ON THE BACK OF THE FREEZER SHAPED LIKE A U THAT MOVES THE ICE AUGER WILL NOT MOVE AT ALL. PLEASE HELP!
  • Anonymous Mar 26, 2014
    model MSD25C2EX*0*, SERIAL HR22013415
  • Anonymous Mar 29, 2014
    auger motor not turning when dispenser lever is pressed
    but ice bin is full of ice
    Problem Solver:
  • 25 Answers
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Posted on Aug 10, 2007
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Ice dispenser wont dispense ice
sounds like a problem with a belt or something or you cango here http://www.theelectricdiscounter.com.au/new/enquiry.asp and ring the nomber
Dec 24, 2011 | Kenmore Refrigerators
The ice maker works perfectly in my Sears Kenmore Elite Refrigerator, but the ice crusher doe snot work. When i put the glass under or I push the lever, no ice comes out. I have removed all the ice sevral...
Push the lever to dispense ice and listen for a small click sound,(the micro switch). If you hear a click you will have to determine if there is a broken wire to the dispenser motor or if the motor itself is defective, This will not be a visual diagnosis unless you fine a broken wire in the hinge area.
Eric
Nov 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice machine makes ice,does not dispense ice
Is it making any noise at all when you press the dispenser? If not check the switch on the dispenser on the front of the door, the actuator may be broke or stuck. The only way to see this is to take it apart, you will see levers and springs, push the dispenser lever and check that the switch is making contact. If you here noise when you press the dispenser like a relay clicking you may have a bad auger motor. Is the ice tray pushed all the way in? And check the freezer door light switch, that is a safety so you cant operate the ice with the door open, if the bulb is out replace it, some models are wired to read through the bulb (dont know why) Please let me know if this helps you out.
Aug 22, 2009 | GE Refrigerators
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
400 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
