Question about LG Washing Machines
Wft7500 top loader
Machine fail to spin error code de
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 410 Answers
SOURCE: i have a ul error code on my washing machine it is
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. The ul error code means unbalanced load. I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on washing machines and other appliances. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
I've got a samsung top loader washing machine, it's giving me a DE error code. The door is closed and the message only comes when it's about time to spin
DE = Door Error
• Check the Door-Lock SW terminal connections and contacts.
• Bring the probe of tester into contact with two terminals of Door-Lock SW.[dE Error]
What Samsung is attempting to say is: check the door lock assembly, your machine will not spin if it "thinks" the door is open...
May 02, 2016 | Samsung Washing Machines
No power but a de code when I spin drum
DE error code shows that there is a problem with the door latch assembly. If this latch switch does not work, the machine will not turn on.
Check the continuity of the door switch with a multimeter on OHMS.
Apr 26, 2015 | LG WM2701HV Washer
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Hi, my Samsung Washing Machine does not want to spin after it has done the rinse cycle, it gives me a dE error code. Please help?
The De code is a door switch error. The door switch is broken or a wire to the door switch is loose or broke. The door.. should be closed while your machine is in spinning mode, thats a safety feature so nobody gets hurt while spinning, if you open door the spinning should stop.
Check your switch by ohming it with a voltmeter http://www.ehow.com/how_5371933_test-switch-ohm-meter.html
If its not the switch, then its a wiring problem..Makes sure the wiring has a power source, by connecting the wires in series with a voltmeter ..
Mar 10, 2011 | Dishwashers
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Dec 07, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
