Canon ir 2200 error code 507
Error 507
SOURCE: error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
Posted on May 30, 2008
jalamb
  • 105 Answers
SOURCE: What does error code E0002020001 mean on a Canon
check the platen glass & adf scanning Glass is proper
That mean white plate error.
Posted on May 10, 2010
canontech
  • 1219 Answers
SOURCE: What does error code E602-0003 mean on an IR 2200?
Try this:
Turn off copier, simoultaniously press 1 and 9, hold it and switch the machine - this is defrag mode for hdd.
If that does not help, replace hdd and upgrade it over service support tool.
Posted on Jun 14, 2010
canontech
  • 1219 Answers
SOURCE: Error Code #E000602-003
0003 A sector fault is detected on the HDD.
You need to replace HDD, upload system, language,...
Call service, beacause all of above is done over service support tool.
Posted on Jul 02, 2010
SOURCE: MY CANON XEROX MECHINE MODEL:
my xerox machine is problem error code : E000002-0000
PLS help me i solve the problem
Posted on Jan 25, 2011
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
Nov 05, 2015 | Office Equipment & Supplies
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
Solution :
Apr 29, 2009 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
