Lavor superwash 160 manual - Washing Machines
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
Lavor superwash 160 exploded diagrams
try e spares on the internet they may help
Jan 17, 2014 | Kitchen Ranges
Weak pressure
seals may be worn although a high speed pump is not normally recommended for siphoning due to pump rotating at an rpm as fast as the motor belt drive gear drive or slower rpm pumps will siphon much better.
Dec 30, 2013 | Garden
I have a lavor star stream cleaner. There is no steam coming out only water
Try cleaning out all parts of the machine,including any filters or possibly buy a new filter if needed-there may be some blockage inside your cleaner,which is not allowing the machine to heat up properly.
Feb 21, 2013 | Coffee Makers & Espresso Machines
Lavor thermic 3/s
remove the spark plug and see if the cylinder if full of gas if so replace the needle and seat in the carb
Aug 09, 2012 | Garden
Washing machine doesnt spin on superwash
This can be fault on the memory of the program controller as none of the other programs are being executed. Please remove the panel and processor controller board. Check for moisture or connection issues. If not this can be confirmed only with a swap and a new one should not be bought unless this is confirmed.
Oct 26, 2011 | Maytag Performa PAV2200
Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
Feb 28, 2011 | Kitchen Ranges
In whirlpool superwash xl a-72 how to operate the rinse option,i am manually doing it by using 3 buckets, to rinse each dress...pls let me know how to rinse in the machine..
You need a manual!
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 21, 2011 | Washing Machines
Superwash button constant flashing
I do not have a solution but also have the same issue. That is when putting on a cotton programme, the superwash light comes on at the end of the programme and I am unable to open the door as it remains locked. I then have to put it to a rinse or spin cycle as it does not seem to have spun the clothes at all.
Jul 15, 2010 | Hoover H140E Front Load Washer
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
