I have a sharp ar5620 mfp and I cant reset the developer lght
I managed to clear the maintenance light but I cant seem to manage to clear the developer light even after replacing the developer
Cogz
  • 1326 Answers
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Posted on May 09, 2008
disastertech
  • 62 Answers
SOURCE: toshiba 1360
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
Posted on May 11, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Posted on Sep 01, 2008
  • 153 Answers
SOURCE: Sharp AR-156 Developer light stays on.but the
in service mode
Posted on Sep 28, 2009
  • 257 Answers
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Posted on Dec 01, 2009
Sharp ar5620 sl cod f2
normally it is from the development unit or ATC sensor from the toner
Nov 15, 2015 | Sharp AR-5320 Black and White Copier
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Maintenance require code vc
The VC code on a sharp mx-2700 is the cyan developer has reached its maintenance cycle of 60,000 copies. to clear this code enter sim mode #, *, C, * then 24-5 to clear dv count.
Jan 28, 2014 | Sharp MX-2700N Color Copier
Sharp ar 203e maintenance indicator reset solotion
It is SIM 20-1 for maintenance counter reset.
Press
[Clear] key -> Exposure mode selector key -> [Clear] key -> Exposure mode selector key
to enter to maintenance mode.
Add with UP arrow 20, press Start button, add with UP arrow 1 and press Start button. 000 will flash, exit with pressing Clear key 3 times.
It will only reset the counter, I recomend also replacing the parts (drum, develop, blade,..) and clean it.
Mar 21, 2013 | Office Equipment & Supplies
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
27 people viewed this question
k24674
jasbo
jasbo
