Question about Aiwa AWP-ZX7 CD Shelf System
Problem with cassette tape deck
My problem is actually with a NSX-AJ22 Compact Disc Stereo System with 2 cassette tape decks. The tape deck on the right or "B" or "#2" deck is the problem. I have a tape in it that I can not get out. The deck will not open when I push on the door. When I turn on the stereo system the faulty deck starts making clicking noises then stops. I am unable to play the tape in that deck. I need professional help. Please advise me with your expertise. Thank you for your time and attention to this matter. Take care and have a most wonderful day and an even better weekend. Sincerely, Michael Norman mdnrmn2004@yahoo.com
  • devern1 Oct 28, 2008
    i HAVE AIWA NSX-D7. BOTH TAPE DECKS DO THE SAME THING CAN GET THEM TO WORK.
SOURCE:
SOURCE: Clicking sound in tape deck
All Aiwas  are prone to this problem.  The doors are a real pain and easily give up the ghost.  I have 2, both probmatic in this direction.
I have spoken to others about this problem. Seems no easy fix.
Have you in your case, tried leaving and old tape in the tape part of your  unit . The noise you hear, usually starts when tape unit area doors are about to pack a wobbly. Unless under warrenty, proberly,
not worth getting fixed.    It seems something gets weak in the activation part and get a mind of its own.  Very common after about 3 yrs of ownership.  All the best: jamz
Posted on Oct 25, 2007
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
http://www.donberg.ie/warehs/groupba.htm
try here
Posted on Jan 18, 2009
  • 4234 Answers
SOURCE: My Compact Disc Stereo System NSX-AJ50 is tripping
One or more of the output transistors has failed or you have a bad speaker. Try disconnecting both speakers and turning on the unit. If it still shuts down, then the transistors are likely to be defective. These can be replaced for about $15-$25 plus labor at any service shop that handles audio gear.
Dan
Posted on Feb 20, 2009
  • 4234 Answers
SOURCE: I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Posted on Feb 23, 2010
Grubhead
  • 5683 Answers
SOURCE: i have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Posted on Feb 27, 2010
Only one spindle turns on cassette player
It is probably a loose or broken belt. I do not know the unit so this is just a starting point.
Aug 10, 2014 | Aiwa Audio Players & Recorders
Panasonic SC-AK45 stereo not playing cassette tapes
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
Feb 23, 2013 | Audio Players & Recorders
Where can I find a repair manual to replace belts on my Onkyo Stereo Cassette Tape Deck TA-630d
I have found a service manual for you that can be downloaded free:
http://elektrotanya.com/onkyo_ta-630m-sm-tape-deck.pdf/download.html
After the page is appeared fully, click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
gylacz
Mar 31, 2011 | Onkyo TA-RW255 Single Cassette Deck
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Dan
Feb 23, 2010 | Aiwa Audio Players & Recorders
No sound
Make sure speakers are still good and not blown
Aug 01, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Double cassette deck inoperative
im sorry but your deck is broken but give this a try get a tooth brush and clean the inside of the tape deck make sure u clean everything
Dec 31, 2007 | Aiwa NSX-AJ70 Shelf System
Aiwa AWP-ZX7 CD Shelf System Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
