Question about 2002 Mazda Protege Fuse
Is there a fuse for the sunroof in a 2002 Mazda protege?
  • Bussman Master
  • 635 Answers
Yes there is. check the fuse box.
Posted on Oct 14, 2013
The sunroof is half closed and the other half is slightly open. How do I fix this ?
Do you mean that your sunroof is stuck halfway and now won't open or shut correctly? This sounds like a normal setting with the roof half closed and the deflector at the front beginning to close. If it won't move from there first check the fuse but it would be smart to look for silly simple things like a piece of road debris stuck in one of the runners.
Oct 22, 2015 | 2002 Protege Lx Sunroof Motor
Where's Mazda Protege LX 2.0L, 2002 windshield wiper relay snd fuse?
possibly in the engine compartment (Relay) and passenger side glove box for fuse
Feb 05, 2015 | 2002 Mazda Protege
Sunroof open
check fuse for sunroof and map lights ,check to make sure they are connected,most likely there on the same circuit
Jun 05, 2013 | 2002 Mazda Protege
Need to disable air bags on 2002 mazda protege 5
Disconnect the battery form the car. Remove the airbag fuse under the bonnet. Do the bumper replacement then re-install the fuse before putting the battery back in.
Dec 30, 2012 | 2002 Mazda Protege
EXACTLY WHERE ARE THE SUNROOF DRAIN TUBES LOCATED ON A 1995 MAZDA PROTEGE? WHAT AM LOOKING FOR? NO HEADLINER IN THE VEHICLE.
The drain tubes should be located on the four corners of the factory sunroof assembly, running down the four windshield pillars.
Jan 16, 2011 | 1995 Mazda Protege
Mazda protege with no dashlight on.
First you must cut the Dimmer wire from your stereo installation.Second, replace the 5amp or maybe the 7amp fuse that blew at the fuse panel near the LEFT foot rest.If you are certain that all the fuses check fine, then go to your MAZDA dealer and purchase a new thumbwheel dimmer control,because the rheostat has burned in your present one.Do not reconnect the dimmer control wire 2 your stereo wiring,because U don't need to.
Aug 30, 2009 | 2002 Mazda Protege
Sunroof problems and heater
first the easy problem is the blower. it has a faulty resistor. it works on 4 because 4 bypasses the resistor to give you full power.
the sunroof sounds like you've got a shorted wire somewhere. the open power wire has to be shorted to a 12v power sorce. there should be a sunroof fuse. check the owners manual for it's location. but if the wire is shorted it may open without it. you may have to remove the headliner to unplug the sunroof motor itself.
Jun 26, 2009 | 1999 Mazda Protege
2002 Mazda Protege Fuse Logo
73 people viewed this question
Top Bussman Vehicle Parts & Accessories Experts
ivan whisker
ivan whisker
joseph m fucci
joseph m fucci
Level 1 Expert
Demi DeMeanor
Demi DeMeanor
Are you a Bussman Vehicle Part and Accessory Expert? Answer questions, earn points and help others
