Question about Dell Ethernet Card Network Adapter
Dell mtc2 network
Im havin trouble getting my dell Ethernet adapter working off the dell website. its not taking the drivers. its on windows home edition
burns-o
  • 114 Answers
SOURCE: Network and wireless not working
check to see if driver is installed. click the start menu, Right Click "My Computer" Click Properties, go to the "Hardware" Tab, click "Device Manager"and check under "Network Adapters" to see if your card is there. if not, there will be a yellow ? right beneath "Network Adapters", see if your card is there, if not, you can google search the name and "driver download" to get your PC the driver. After installing the drivers for it, restart your PC, and you should be good to go. Please Rate My Solution
Posted on Jun 01, 2008
GSAN
  • 106 Answers
SOURCE: Window Re-Install and no Ethernet Driver
use another computer to get the drivers from the dell webite (at home, library, friends) and save them on a CD or removable media. This would be the fastest and cost effective way. If you can get on the net to post this question then you can download and save the drivers as well
Posted on Jun 21, 2008
SOURCE: Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Posted on Dec 28, 2008
Code Blue
  • 86 Answers
SOURCE: Dell ethernet card
You must buy a pci spec'ed Ethernet care. This will fit into the white socket on the system worse case you go buy a USB based ethernet adapter.
Posted on Mar 19, 2009
vincent721
  • 240 Answers
SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Posted on Apr 03, 2009
My dell inspiron 1545 cannot connect to internet as it says i have no network adapters installed. How do i do this
Hi Anon
Your laptop should come with an Ethernet connection as well as wireless connections, try making a wired connection via your Ethernet port, these are usually more reliable than wireless connections.
When I have experienced these sort of problems it is usually because of a missing driver.
Check that you have the proper drivers for your internet connections installed, these should come on a disk that is supplied with your laptop.
Finally check this link for Microsoft's official network trouble shooter.
http://windows.microsoft.com/en-gb/windows-vista/troubleshoot-network-connection-problems.
Sep 14, 2014 | Microsoft Windows Vista Home Premium with...
Im at the device manager and I have a yellow triangle on network adpater
it means that the dell ethernet card has no driver... try to install the driver
Oct 30, 2010 | Dell Ethernet Card Network Adapter
Windows 7 doesn't see network card after sleep
Hello
Go to control panel,system,device manager,network adapter,Right click on your adapter.
Then properties,power management.uncheck all power saver and wake options.
May 27, 2010 | Dell Ethernet Card Network Adapter
Just reinstalled xp on a dell dimension desktop 8250 and the ethernet NIC Card just does not show up in the network settings. Everytime I look up the card in Device Manager it has a question mark. I did...
if u have another way to contact dells website with eather a flash usb or a cd get the drivers from dell for you nic then go start/control/system/device manager and update your drivers for that nic
Dec 05, 2009 | Dell Ethernet Card Network Adapter
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
The network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Jun 21, 2008 | Dell Dimension E310 PC Desktop
Dell Ethernet Card Network Adapter Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
