Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-47WXD63G I have a convergence problem where the RED is ghosting above all colors: I have the service manual that treats all tv's in this line up to 56" Can anyone explain to me how to enter the service mode? I have the instructions but can't seem to get there. Here are the details: When minor adjustments need to be done to the electronic controls, the method for entering the service mode without removal of the cabinet back is as follows, using the remote control: Select SET-UP icon, enter ?Program CH? and select CABLE mode in ?Input Setup? option. Select TIMER icon and set SLEEP time for 30 Min. Press ?OK? then VOL up to exit menus. Tune to the Channel 124. Adjust VOLUME to minimum (0). Press VOL ← (decrease) on receiver. Red ?CHK? appears in upper corner. To toggle between aging and service modes: While the ?CHK? is displayed on the left top corner of the CRT, pressing ?OK? and ?VOL? UP on the TV simultaneously will toggle between the modes. Red ?CHK? for service modeand yellow ?CHK? for aging. Press POWER on the remote control to display the service adjustment modes menu, select adjustment by pressing the VOL right/left buttons and CH up/down buttons on the remote and OK to enter the adjustment. Service mode menu
  • kyle5252 Dec 10, 2008
    i am having a convergence problem. I have shadowing and have gone into the convergence section and the "t's" are all off and I fixed those and nothing happened.....I assume something else is wrong (something has burnt out or I need to fix something else). What do you think is the problem? panasonic pt53w 53.....any help? How much will it cost to get fixed by a pro?
    kyle5252@yahoo.com
I have the panasonic pt 47wxd63g, no sound, no video, red light keep blinking every 5 seconds, (not a 3 blink pattern) ..is the power board is the problem? what is the solution?
thanks
Posted on Jul 23, 2011
My remote has no letering left on it dont know what to do?
Posted on Dec 01, 2008
Can I get a copy of the service manual if you have it in a file format? If so, here is my e-mail- vortexmd@comcast.net. Im am having the same problem you had with the red convergance. Im going to attempt to replace the two IC's and need all the help i can get.
Thanks in advance,
Eric
Posted on Nov 18, 2008
    President:
  • 3,130 Answers
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
Fix convergence tv cost
Typically the repair calls for Replacing (2) STK-392-110 convergence IC's and usually 1 or 2 maybe more, baby blue 2.2 ohm resistors
then you have to manually align the 3 colors (red,green,blue)
with the remote in the menu or in the service menu!!!!
Nov 15, 2013 | Panasonic PT-56DLX25 56" HDTV
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Pt-47wx53g has red ghost. I tried adjusting convergence but some will not adjust
You have a problem with the convergence output IC's. They need to be replaced. This is a very common problem with all projection tv's as those IC's are high current components.
Jun 10, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red ghost images
Yes there is a repair kit for your model which contains the two Convergence ICs and the 6 feed resistors. The kit alkso has step by step instructions with pictures so you can easily do the repair. Heres the link for the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jun 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Ghosting - colored shadows - guns out of alignment?
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Ghosting in Red, Green and blue
*Screen Looks 3-D
*Colors wont align
Problem #2
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projection tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
RED color wont converge with + PT-53WXD63
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Panasonic PT-47WX53 47" Rear Projection...
turn off the color and see if its still ther if so possible convergence  alignment.
Sep 30, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
810 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
