Question about Nuvo Simplese D 4-Source 4-Zone Audio System System
Nuvo NV-A4 3 of 4 zones work fine. Zone 1 when turned on lights up but just get a humming sound from speakers? Ideas?
3 Suggested Answers
SOURCE: Nuvo NV-4A Keypad Flashing/Won't Work
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Posted on Oct 12, 2009
  • 382 Answers
SOURCE: I have nuvo 4 zone switch that I cannot get to
That indicated there is a short or incorrect wiring on the combus of the keypads.
Remove the keypads from the walls and unplug them one at a time.
Then unplug one at a time from the all-port until it works.
The last one you unplug will be the offender, inspect the cat-5 crimp for a pair or wires that are in the incorrect order.
Cheers!
Posted on Jan 07, 2010
No power light at controller no lights at key pads
What is the solution?
I'm having the same issue.
Nuvo has been installed about 3 months.
Nov 11, 2012 | Nuvo Simplese D 4-Source 4-Zone Audio...
Nuvo Essentia low volume on left side speakers
check the wires make sure thay are not loose or partial connection
May 29, 2012 | Nuvo Essentia Amplifier
In regard to my Marantz AV Surround Receiver, Model number SR5005, I cannot get the Zone2 speakers to play. I have followed all the instructions, and nothing works. Does anyone know what I need to do...
have the same model. just got it to work. but, struggling with one part. here's the scoop. 1. Plug your second zone speakers into the SURR BACK/AMP ASSIGN speaker outputs on the unit. 2. You need to "amp assign" the speakers to zone 2 by pressing AMP, MENU, select SPEAKER SETUP, AMP ASSIGN and scroll to ZONE 2 - this will force the sound to the speakers that you plugged in. 3 - Turn on Zone 2 (press Z2, press ON button on remote). Use the UP/DOWN arrows to select the input for Zone 2. I've only been successful in selecting USB and plugging my iphone in for zone 2. For some reason, I cannot get the SAT (cable box) to play in both zone 1 and zone 2 at the same time. But, I can get SAT in zone 1 and USB in zone 2. Hope that helps. Let me know if you can solve my issue...
Apr 13, 2011 | Marantz SR5005 Receiver
Cheers!
Jul 19, 2009 | Nuvo Simplese D 4-Source 4-Zone Audio...
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Serial codes for nuvo simplese
I asked Nuvo about this and they said that the RS232 port was never setup for control, it is only to be used for programming when they are initially setup by Nuvo.
I have codes for the Essentia and Grand Concerto that I have written but non for the simplease as Nuvo said it cannot be controlled.
Cheers,
Nov 01, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Sep 15, 2008 | Yamaha RX-V659 Receiver
Jul 12, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
Nuvo Simplese D 4-Source 4-Zone Audio System System Logo
54 people viewed this question
Top Nuvo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nuvo Audio Player and Recorder Expert? Answer questions, earn points and help others
