Question about Abit IC7 Motherboard
Diagram Cant find a switch power and Reset with a LED cant find a socket on a mother board
  • 5,660 Answers
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires go to from the Front Panel; is the Front Panel header
http://www.ebay.com/itm/ABIT-Computer-IC7-Socket-478-Intel-Motherboard-w-Pentium-4-3-0-GHz-CPU-/171034074235?pt=Motherboards&hash=item27d26cdc7b
Motherboard installed in computer case, the Front Panel header is on the Bottom/Right corner; and is White it color.
Two rows of contact pins.
(I like the Zoom In feature. Just set your mouse cursor in the middle of the photo to activate it, and then move your mouse cursor around)
Looking at the two rows of pins, you will see there are some missing in the middle.
Essentially can be said as having pins on the Left, and pins on the Right.
It is my belief that the pins on the Left side, are what you want.
Number the pins across the Top row
Let's start at the Left side.
Pins 2, 4, 6, and 8.
Now number the pins on the Bottom row, Left side.
Look like there may be four pins, so number from the Left,
Pins 1, 3, 5, and 7.
It is my belief that;
Pins 2 and 4 are for the Power On LED light
Pin 2 being for the Positive ( + ) wire
Pins 6 and 8 for the Power On switch
Pins 1 and 3 for the HarDDrive activity LED light. (HDD LED)
Pin 1 for the Positive ( + ) wire
Pins 5 and 7 for a Reset switch
I think the pins on the Top row/Right side, may be for a speaker.
A lot of times though, these pins are not even used.
One pin may have been a 5 Volt test area for the factory.
Other pins may be for technology that isn't used today, or used readily.
Such as Infrared Remote, and so on.
(Huh! Always thought Infrared was spelled Infared.
Good Ol' spellcheck)
I would SUGGEST, using a 2-wire LED to check my theory.
For additional questions please post in a Comment, or Reply; at end of solution.
Regards,
joecoolvette
Posted on May 07, 2013
5 Suggested Answers
  • 119 Answers
SOURCE: mother board
Here you will find the correct manual:
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&fSEARCHTEXT=bx133
Posted on Jan 06, 2009
  • 256 Answers
SOURCE: MOTHER BOARD CONNTIONS
Please, I understand that you feel bad for what happened to you. We are not in the business to console you, but to help you out of what happened. You have attempted to do something that I would not even thing of doing and that is to try to disconnect wiresm without some notes to put them back. Your short description was very difficult to understand. We are here to fix things, which sometimes happen naturally and sometimes they happen because someone dove into the swimming pool before learning how to swim. Forget all that happened. All we want is to fix what you have that does not work. In order that we accomplish this we will need a detailed description of what happened. Then, we can put two and two together and they always come to four. TWO AND TWO MAKE ALWAYS FOUR! what we need is some information, based on which we can duplicate what what happened in the lab. Do you know that before we advise you, we have to duplicate in our lab what happened, so we can undrestand it better. So, please, we want to help you. All we need is the information. Our company "Fixya" gives this as a free servce. Should there be a need of a part, we will give you an estimate, before we move our little finger without your consent. <arzobconst@yahoo.com> My name is Constantin
Posted on May 24, 2009
SmartAviator
  • 449 Answers
SOURCE: cant find the manula anywhere. can you help?
Try visiting http://www.abit.com and fnd the users manual from support or download section.
Posted on Jul 18, 2009
joecoolvette
  • 5660 Answers
SOURCE: cant locate user manual for the Abit AN52 MOTHER BOARD
http://www.nodevice.com/driver/AN52/get64989.html
In the verification code box type the letters you see, then click on Download in the blue rectangle next to it.
On the next page the drivers given are;
1) nForce 520 Chipset driver
2) NvRAID Installation Disk
3) Marvell Gigabit LAN Driver
4) Realtek High Definition Driver
No Win7 drivers.
Regards,
joecoolvette
Posted on Aug 23, 2012
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
I HAVE IBM X3400 I CANT POWER ON.I THOUGHT THAT IS SWITH PROBLEM AND I REMOOVE MICRO SWITH.SWITH HAS TWO CONTACT.ITS ALLWAWYS SHORT WHEN I PRESS IT SWITH IS OPEN CCT.IS THAT CORRECT?NOW I CANT SEE EVEN...
You should see the green light on the mother board whenever the power supply is plugged in, so either the wall socket is bad or the power supply.
Try plugging a lamp into the wall socket to make sure a circuit breaker did not trip.
If the wall socket is good, I would suggest the power supply is bad.
At least the power supply fan should go on.
However, if you want to be sure, they sell a voltage checker with lots of lights to show all the outputs of the power supply, for about $10.
Or you could take the power supply out and take it to a shop to be checked.
A new power supply should run about $30.
Dec 27, 2010 | IBM x3400 Server
WHERE TO PLUG IN POWER SWITCH
on the mother board look at the side of the pin of the power switch on the mother board, at the side there is HD LED for hard disk, RESET for the reset, PW for power just the way it is started put it like that.
Mar 03, 2010 | ASUS P5QL-EM - Motherboard - micro ATX -...
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Wiring diagram of hdd.power reset .power switch.led power .led. and speaker contacts on a microstar ms 6390 mother board
Here's a link to the support page for your board. You can download the User's Manual from there.
Click Here
Feb 23, 2009 | MSI Computers & Internet
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Abit IC7 Motherboard Logo
54 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
