Question about Garden
Replace belt I need to know how to replace the belt on yard man mower
  • 79 Answers
If you take the deck of first you can see it better take circlip off bottom of steering gear lift steering wheel up a little bit and fit new belt
Posted on Jun 12, 2013
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: I have an mtd yard man mower that wont stay
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
  • 376 Answers
SOURCE: I need a belt diagram for a Landpride 6' finish mower.
Check out their website and look under manuals. http://www.landpride.com/main_products/main_gm.html
If you don't find it there, I'm sure customer service could hook you up...
Posted on May 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: I need to replace the pull cord on a 4hp, yard machine, 21",mower
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: how do you replace the pull string on a yard machine push mower
Do you have your model # and what is the name of the engine brigg or tec, kohlar, honda
Posted on Jul 08, 2009
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Lawn mower transmission
This can be a loose belt that is slipping, low fluid in the transaxle, a bad pump (if hydrostatic transaxle) or worn gears, start by checking belt tension, then replace the fluid and filling to proper level, if that fails, the trans will need to be inspected for internal damage to pump and gears
Oct 16, 2013 | Yard Man Garden
Don't perpelle
broken drive belt, or control, worn out drive wheels, replace or repair as needed
Jul 03, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
REPLACE A BELT ON THE YARD MAN EDGER
Hi try this site just look up your model and it will show you a parts list in exploded view.
Aug 02, 2009 | Yard Machines Red Edger
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
hello
hope this helps
Mar 13, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
