Question about LG zenith zd300 30 pint digital led dehumidifier factory refurbis
Zeneth zd300 error code 01
What is the repair for error code 01.
Why is the empty bucket signaling full bucket
See if there is a float switch in the unit that may be stuck.
Aug 31, 2014 | Zenith 30 Pint Dehumidifier ZD300
Have a year old lg dehumidifier and a code of 01 appears in the window and will not start.
The error Code 01 indicates that either the air intake filter is dirty and needs to be removed and cleaned and/or the water collection bucket is not installed properly. Turn the unit OFF & unplug it, before attempting any service work.
Hope this helped you & thanks for choosing FixYa.
Sep 12, 2011 | LG LHD45EL Dehumidifier
My Zenith dehumidifier model #zd300 will not work. It is only one year old and worked fine when I shut it off for the winter. Now when I plug it in the full bucket light blinks and the humidifier setting...
I had the very same problem with my Zenith ZD300 dehumidifier. After getting no help from the manufacturer and realizing that it was going to cost $45 just to figure out what was wrong with it, I dismantled the dehumidifier myself in search of a solution. I suspected it was the humidity sensor, so I ordered the part off Repair Clinic website (repairclinic.com). It cost $18.20 plus shipping. AND IT WORKED!! I was so relieved that I wouldn't have to buy a new dehumidifier. It's been running for a day now, so we will see. Here's the website link:
http://www.repairclinic.com/PartDetail/Thermistor/6877A30013R/1462299
Part info:Thermistor6877A3001R
Good luck!!
Aug 13, 2011 | Dehumidifiers
01 error code
check sw. on dehumidifier possibly stuck open
Jan 15, 2010 | Comfort-Aire BHD-501 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Has ch 01 light on
I'm having the same problem. I spoke with LG today and this error code means the unit is not calculating the correct humidity percentage. I told him that I don't really care what percentage it calcs, I just want it to collect water. He told me there was no way to override this and that it will need service to operate.
Aug 08, 2009 | LG LHD45EL Dehumidifier
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Jun 26, 2009 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
May 29, 2007 | LG DH504E GoldStar Dehumidifier
LG zenith zd300 30 pint digital led dehumidifier factory refurbis Logo
32 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
