Question about Umarex USA 225-2155 Steel Storm .177 Airgun - Air Pistol
Umarex Steel Storm
Where do you get the red dot sight, grip, and silencer for this like in the pictures, and how much would each one be?
Help to reasemble a electro dot sight a parts list might help ?
I know about classic scopes... (not so much)
DOT, red or electro ...??
Besides under the windage and elevation adjustment (zero) screws... I can't think of a third "spring"...
Knob springs... perhaps ((but these "SPRINGS" are usually tempered steel compression washers)).
Try putting your model number with a search for "EXPLODED+VIEW"
Hope this helps.
Go to Bing homepage
Nov 05, 2016 | The Optics
Why are the sights in my scope diagonal instead of vertical?
Have you turned the scope in the rings? I would suggest loosening the rings, turning the scope so that your reticle is where you want it, then re-tighting your rings.
Apr 24, 2014 | Truglo Sights Truglo Crossbow Red Dot...
Bought a Barska red dot sight and it needs the battires changed were is the battery soure on the sight so that I can change it out.
The battery's are under the large top cap, use a screw driver or coin to remove. watch for how they come out keeping in mind the positive side up. Hope this helps Fix Ya up.
Jun 11, 2011 | Barska Optics Barska 1x30 Red Dot Scope...
How do you align sight
Here is a manual, it gives you a brief description on how to align and sight it in. Red dot manual
Jan 21, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
NEED INFO ABOUT ADJUSTING WINDAGE & ELEVATION ON MY MILLETT SP2 RED DOT. I LOST OWNERS MANUAL &NEED TO KNOW WHAT EACH CLICK IS EQUAL TO AT 100 YDS
the best way to sight in your red dot is clamp your gun in a gun vice or work mate? so it cant jump about!!!!!!! look through the barrel at a post say 100yds away then tweek the red dot or croos onto this post,,then test fire the gun and tweek the scope till its shooting were it points,,easy,,,
dont let the gun move at all,,,,you need to remove all the wobbely bits,,your the bigest wobbely bit?
an im not being nasty,,,you cant tweek a scope hand held?
Nov 27, 2010 | Millett SP2 Compact Red Dot Sight 5 Min...
The dot on my tasco red dot scope (BKRD30/22) fuzzy and is more smear than "dot". whats wrong here?
that is the problem with red dot sights.if your eye sight is not 20-20,you will get a star burst or halo.glasses will help.
Mar 19, 2009 | Tasco Scope Guide Quickly Zeroing Rifle...
Umarex USA 225-2155 Steel Storm .177 Airgun - Air Pistol Logo
Top Umarex Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Umarex Optic Expert? Answer questions, earn points and help others
