Question about Water Heaters
How water temprature not going above 55.
Some one can you tell me please, which parts I have to change to increase temprature above 55. I want to increase temprature till 68 degree.
  • Water Heaters Master
  • 5,089 Answers
Unknown what product you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Add a comment and describe product in detail
Posted on May 07, 2013
How do I change a r.v propane water heater to a 55 gal electric appartment size water heater
Changing out the water isn't difficult, but an electric heater needs a lot of electricity. Doing the wiring is going to be the hard part.
The plumbing is easy. Cold water in, hot water out. Two connections. Cap the propane connection.....
Oct 09, 2015 | Water Water Heaters
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
How do i change my natural gas hot water heater to propane
Replace your orfices. You probably have #40 and you will need #55. Write down the Model number, and any information from your regulator. A plumbing/heating parts supplier will help you. You may need a new regulator also.
Jan 28, 2013 | Whirlpool Water Heaters
Have protherm 100ec boiler british gas has replaced almost every part boiler will fire temp gauge rises to about 55 flame increase in strenght for about 10sec then boiler cuts out also they keep trying...
Any other symptoms? Is the fault apparent only when drawing hot water? Does the boiler re-light later? Alarm messages? F1? F3 for example?
It may well need a powerflush, but it's best to find out before spending big money with BG.....wish I could get away with charging that much for a flush!!!
FYV
Jan 27, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Gas burner shuts off after water is . finished heating and dosent continues to turn flame dose not maintain water temprature and flame shuts off dose not stay burning
sounds like the gas valve is no good call the 800# off the side of the water heater if there is one they can tell u if it is under warranty for a new one or usally can give u a price and ship u one ups if u have a credit card and it is not covered
Jan 14, 2011 | Reliance Natural Gas Water Heater Control
My Reliance water heater high temp shut-off keeps tripping.
YOUR WATER HEATER ME BE IN DCS OR PANAL SYSTE\M SO YOUR THREMOCOPL GIV YOU WRONAG TEMPRATURE SO YOUR WATER
HEATER SUTT DOWN
Mar 06, 2010 | Water Heaters
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Water Heaters Logo
305 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
