I cracked the screen on my inspiron M5010 so I got
I cracked the screen on my inspiron M5010 so I got a new one and installed it. After installation, the new screen has lines of all colors across the screen. I ran diagnostics and it gave me error code 2000-0413 which means the LCD cable is unplugged, yet I can still see stuff on the screen. I still have backlight too. I checked to make sure the plugs see seated well but still have the lines. I got a new LCD cable and installed it. Exact same thing. The video card is fine, picture is perfect when I plug it into the tv. What else could be wrong?
  • Computers & ... Master
  • 5,660 Answers
I would have the old Video Cable (LCD cable), AND the new Video Cable; checked with a multimeter set to OHM's (1K), for Continuity.
An inexpensive multimeter is about $5 to $12 bucks.
Suggest, take both Video Cables down to the nearest small computer repair shop, and have the resident tech check it for Continuity.
Should only be a couple of bucks.
"But it's a new LCD cable"
So?
New LCD cable checks fine, the problem is;
A) You are not getting the LCD screen side of the LCD Cable, plugged in correctly.
It may seem like it is.
Motherboard side connector isn't the usual male plug connector.
Looks simple to connect, but also in the same instance looks like it may be a problem child to connect.
The LCD screen side connector of the LCD Cable, can be tricky to get plugged in correctly.
It can be loose enough at that connection, that it will not make full contact; and your little peepers will not see it.
(Also needs to be re-taped after connecting to LCD screen)
2) LCD screen replacement could be the wrong one, or is a faulty unit.
3) http://www.ebay.com/itm/New-Dell-Inspiron-N5010-M5010-15R-LCD-video-flex-cable-4K7TX-04K7TX-50-4HH01-101-/400479996437?pt=LH_DefaultDomain_0&hash=item5d3e77ca15
With this LCD Cable it looks as though it may be easy, to Not get the motherboard side of the LCD Cable; plugged in tightly, and correctly.
Post back in a Comment, or Reply; at the end of this solution.
Regards,
joecoolvette
[If you can't get through using the above methods, then post your reply as a Solution.
FixYa has undergone a site change, and it seems certain functions are not working correctly.
After you post as a Solution, Fixya staff can clean it up.....
(They can put is as a Comment or Reply ]
Posted on May 07, 2013
5 Suggested Answers
Mark_Webber
  • 472 Answers
SOURCE: Inspiron 8500 display dead
I had one of these with a Geforce 5200go video card in it. They get quite hot and will just die. The video cards can be found on Ebay from time to time fairly cheaply.
Posted on Apr 08, 2008
parrotheadpc
  • 2600 Answers
SOURCE: My dell inspiron 700m inspiron screen cracked so I
The flat cable simply trasfers visual data to the screen to be displayed. The power for the backlight comes through the inverter which takes the low voltage DC power and converts it to high voltage AC power for the backlight. I am not sure what the usual thermal range is for that cable. Just make sure that all connections are tight. Loose connections can cause thermal conditions and shorten the life of all the components. If that flat cable was bad in any way, it most likely would not even carry a signal.
Posted on Nov 29, 2009
zecs
  • 123 Answers
SOURCE: lp154w01 lcd doesnt work...lights up
chnge lcd
please click yes for vote
Posted on Jan 16, 2011
SOURCE: New laptop lcd display not working
check all usb connections i just fixed a emachine that seemed to boot up but no display would show lcd or ext. so i got to looking and one off the usb ports was broke and bent downt into the opening and shorting out when i removed it and turned back on it started booting up as normal
Posted on Apr 01, 2011
NEED TO KNOW IS IT WORTH FIXING A CRACK SCREEN NO PICTURE COLOR LINES.
You have to take it into a shop and the cost will be more than a new set. You cannot buy a screen that big and install it yourself.
Feb 14, 2014 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
My dell inspiron m5010 doesn't turn on I've tried
You don't turn off a machine when updating the BIOS for any reason.
the system boots from the BIOS, and if the BIOS is corrupt due to an incomplete update. it's going to be very tricky to get it back on. contact Delly on the issue. best of luck Ram
Jan 03, 2013 | Computers & Internet
Getting a vertical green line across my laptop screen
SOUNDS LIKE YOUR SCREEN IS CRACKED OR THE LED INSIDE THE SCREEN
Jul 14, 2012 | Computers & Internet
Hd sound deleted by acciedent on my dell inspiron m5010 what do i do
go here and enter the tag number of your computer and download the audio drivers for your version of windows, install them and your sound will work
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=dhs
Apr 13, 2011 | Computers & Internet
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
I have a Dell 1501 Inspiron Laptop. Upon starting, or trying to start, the screen goes to 3/4 of it narrow vertical multi-colored lines with what appears to be a black ink spot splattered across the page,...
Re-install windows... Your hard drive may be corrupt. Get the disc for the operating system and try a repair install first, if that does not take, do a full install (you may lose your data but it may be gone anyway). If that doesnt work, than you need a new hard drive. Make sure it starts up to BIOS screen first, it should do this with no hard drive and boot it from a disc using the CD that came with your machine.
Oct 05, 2009 | Dell Inspiron 1501 Notebook
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Computers & Internet Logo
401 people viewed this question
David Payne
David Payne
