Question about Garden
Replace keyway I'm trying to put the left rear wheel back onto my riding lawnmower. There is not a channel in the wheel hub to accommodate the square keyway. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
You will have to go to machine shop have it cut should cost 20.00
Posted on Jun 07, 2014
4 Suggested Answers
vincob
  • 718 Answers
SOURCE: Replaced keyway but lawnmower still will not
The last one I worked on needed a new coil, was not getting spark. Check to see that yours is getting a spark, also check to see that the coil is close enough to flywheel, since you changed the key way. I assume that you removed the flywheel.
Posted on Sep 26, 2009
ryanplex
  • 57 Answers
SOURCE: Replaced both rear wheels +gears
Sounds like when you replaced the wheels you did something wrong and now they are unleveled.
Posted on Aug 24, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Grandson ran lawnmower on tree stump, bent blade
Hi momnpop2...
Either you can rent or if you have a puller the size to fit your flywheel then that is what you will use to pully the flywheel off after you remove the flywheel nut...
There is another way...but be really careful with this method...you can cause damage it if your overley aggressive...
Loosen the flywheel nut about 3 turns...then get two screwdrivers and put pressure on the flywheel from underneath with both screwdrivers at opposite sides of the flywheel.
Then with a brass/bronze hammer or rod strike the top of the flywheel nut as you are prying up on the flywheel with the screwdrivers...you will need some help to do it this way...
Someone to operate the screwdrivers while you hammer on the nut...the flywheel should pop up and then remove the nut and lift the flywheel.
Note: DO NOT USE A STEEL HAMMER...IT WILL DAMAGE THE NUT AND THREADS BEYOND REPAIR.
Please take time to rate me thumbs up
Posted on Sep 23, 2011
RELEASE SWITCH ON REAR OF RIDING TRACTOR.
Double check the drive axle keyway and make sure key is still in there. Without it the drive axle just spins without driving either wheel.
Also if hydro static make sure the neutral lever is re-engaged. Operators sometimes put these in neutral and then forget to put them back when they to use the mower.
Nov 10, 2014 | Garden
When I put in forward or reverse it wont move
Two possibilities. 1. You may have disengaged the free wheeling valve which is usually low on the rear of the machine. It is designed to enable the moving of the machine without the engine running. 2. The wheel that you took off to change the tyre has a key fitted in the keyway in the axle and the wheel hub. These usually have to be slid in after the wheel is on the axle and before the circlip or nut is fitted. Did you check that the axle is not running free in the hub when in gear? You would be able to push the machine without the engine running if this key is absent. Suggest that you jack up the wheel free of the ground and see if it turns free on the axle.
Sep 28, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
How to replace a square key on a lawnmower axle
Marc, if the wheel does not have the channel for the square key, then you have a mismatch and the wrong wheel. Put a new tire on the old wheel, or take it in to a mower shop and ask for an exact replacement.
junkl
May 07, 2013 | Murray Garden
Change blade on gas lawnmower
varies slightly as u didnt give model, i run front wheels onto car ramps and block rear wheels, then in middle of blade is a large bolt hold blade with leather glove and unscrew, put new one on and tighten,
Jun 09, 2012 | Craftsman Garden
I'm trying to take the left rear tire off besides
Wheel has ceased onto hub use bar and bang on the inside of the wheel across the whole wheel
Jun 02, 2012 | 1999 Chevrolet Blazer
I took off one of my rear tires to get it fixed and after I put it back on it will not go into gear. Blade engages and motor starts but no forward or reverse
Hello, What has likely happen is the keyway (Sears part # 123583X) fell out. Verify this by:
setting the parking brake
lifting the side that you removed the wheel from
turn the wheel by hand
If it turns and the axle does not then the keyway is missing.
The part costs somewhere around $3.00 from Sears Parts.
To replace:
remove the snap ring and outer washers
turn the wheel by hand until the keyway channels line up
slide the keyway into the channel
replace the washers and snap ring
test by ensuring wheel no longer turns without the axle
I also recommend that you go to your local auto parts store and get some "antiseize". Put some on the axle before you replace the wheel that will keep it from rusting and making it near impossible to remove next time. I know Autozone sells it in small packets for about a buck-thirty.
I hope this helps. If it was useful please vote yes. Thank you!
May 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I took off the rear wheel to put air in it and have it poped back on the rim since replaceing the wheel the tractor will not ingage in to foward or reverce gear . is there some trick to this
Often there is a keyway in the axle corresponding to another on the inside of the rim hub. Did you check this and make sure the key is there. If the key is gone the axle's turning will not spin the tire.
Jun 07, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
We are trying to remove the wheels and tines from the craftsman roto tiller in order to replace a broken drive chain. We are having a very difficult time getting the wheels and tines off. Any suggestions?
there should be a cotter pin or pin holding a large washer once you have removed these then you have to get the wheel to slide off the axle it has a keyway on it.i have taken a hammer and hit one side of the tire on the backside then turn the tire half way round and hit the tire from the backside and walk the wheel off the axle.if the axle is rusty shoot wd-40 around the axle and wheel .the wheel should slide back on as you line up the keyway when putting them back on.if your going after the chain the tines will have to come off too and the chain box split
May 28, 2010 | Craftsman 8.50 Torque Rating Dual...
I HAVE A ONE YEAR OLD 42 INCH RIDING LAWNMOWER AND THIS PAST WKD THE BACK WHEELS LOCKED UP. IT RUNS AND THE BLADES TURN BUT NO GO. ANY IDEAS
probably the belt poped off the pulley or belt broke the blades run off a different belt , also take off hubcap on the wheel and see if if the drivshaft spins but not the wheel there is a keyway on the axel? but it is prob the belt? good luck
Aug 25, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
