Question about Garden
Need carb linkage diagram for tecumseh LEV120 engine
SOURCE: carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Posted on Mar 26, 2009
  • 246 Answers
SOURCE: Carb linkage hook up
Hello rebel_auto:
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
However, this File may Help.
**The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and the Other End of this Spring Attaches to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
rwvanlue
  • 486 Answers
SOURCE: looking for governor linkage set up took apart
cc4d3bd.jpg hmsk linkages
Posted on Nov 22, 2009
Testimonial: "Just what I needed. Thanks"
rycgl
  • 1545 Answers
SOURCE: i need the correct way to connect the governor
this may not apply exactly to your particular model, but it is for Tecumsehs and may get you on the right track:
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
Posted on Jul 13, 2010
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
Troy Built tiller Tecumseh engine carburetor linkage
I've got one of these that I'm working on myself right now, and all the carb linkage from air vane to springs was gone. I had no info. on this TC-2 engine myself. I found a couple of free service manuals from Tecumseh by Googleing Tecumseh TC-2. And then partstree.com has a lot of good parts break downs, I take the parts numbers I need here and then order through my local dealer.
Hope this helps some what and GOOD LUCK.
Oct 13, 2014 | Troy Garden
yes or a bad safty switch check the seat the brake and the clucth
May 07, 2013 | Garden
Craftsman power washer w/ Tecumseh LEV120 won't start.
the problem will be in the jet up past those holes or in the emulsion tube above the jet
Nov 18, 2017 | Garden
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Need replacement engine or short block for Tecumseh LEV120-361541B
Tecumseh has gone bankrupt so finding parts and engines has been difficult. i would see if i could find a B&S engine with the same bolt pattern to mount on the deck.
Sep 30, 2009 | Toro Lawn Mower With Toro Power Tools
Carb and throttle linkage on a Tecumsen LEV120 361015A
You want the spring to hold tension against the governor.
May 17, 2009 | Garden
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
257 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
