Brivis b20 bufflo gas heater
Runs ok but cuts out on o/temp and rollout have to reset them runs ok for a while then cuts out again might run ok for 2-3 days
  • 86 Answers
SOURCE: Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Posted on Mar 28, 2008
daddyo742001
  • 70 Answers
SOURCE: Ruud Gas Hot Water Heater Shuts Off
If this is a hot water heating system for home heating It may be thermocouple of flame sensor. If it has a sensor rod in the flame check and make sure flame is hitting it. Also a little sand cloth to polish it may do the trick. I have to due this to my gas furnace sensor every couple of years. If this unit has a pilot light and it is weak and yellow verses strong and blue it may need cleaned. Some times you can tap on it while it is burning and it will dislodge plug. If it A domestic hot water heater for washing and such the above still holds true. If polit is strong and hitting thermocouple then replace thermocouple.
Posted on Jul 04, 2009
  • 2976 Answers
SOURCE: gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Posted on Aug 10, 2009
  • 400 Answers
SOURCE: LG Reverse cycle ducted (in ceiling)
Error code CH61 - CONDENSER PIPE HIGH PRESSURE. This can be due to overcharging of the system or the condenser clogged with dust or an obstruction, or condenser fanmotor not working. Hope this helps.
Posted on Nov 18, 2009
SOURCE: Ruud gas pack cuts off after a short heating
burners could be rusted blocking gas from getting across , so it pockets up and ignites all at once ,there also could be a partial blockage in heat exchanger but this is unlikely, or more seriously the heatexchanger could be rusted out with large holes in it so when blower comes on the positive pressure pushes flame back. either way when the roll out switch is tripped it indicates a pretty serious and potentially harmful issue that should be inspected and diagnosed by a reputible company.
Posted on Dec 02, 2010
Furnace runs to temp but wont restart on it's own
It sounds like your furnace one of two things..... once reset, it could be running up to an overtemp condition and is tripping the high temperature limit switch. This typically locks on the blower and the inducer fan and locks out the gas control until the circuit is reset, then it does it all over again. Dirty filter or dirty evaporator coil restricting air flow is a typical culprit.
The other thing could be a tiny bit of oxidation INSIDE the barbed port of the inducer fan where the pressure switch tube slides on. This could be causing either a restriction or a blockage of the positive or negative air pressure required to close a pressure switch when the inducer starts. This will result in a normal sequence up until the gas valve needs to open.
Neither of these suggestions are specifically typical to what you describe, but are two good things to check considering the numbers of parts already installed.
Feb 15, 2014 | Goodman Heating & Cooling
Top rollout switch triggers with blinking code *6*, Furnace only runs with cover off
restart unit as soon as your inducer fan came on pump the 2 wires to pressure switch and wait to see how long it stay also watch the flame at the burner
Jan 27, 2014 | Goodman GMS90703BXA Heater
Thermal Cut-Off Fusible Link P-75173Pentair MiniMax 100
you are fixing the symptom check gas pressure and gas line size heater is running too lean and hot if gas ok check burn tubes for obstructions
Jun 04, 2012 | Pentair MiniMax 100 Aboveground 100,000...
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Apr 30, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Will not turn off on auto?
There are certain faults like "Flame Rollout" and "High Temp Cut-out" that will cause the fan to run continuously until corrected. If the furnace is working then some power is making it to the "G" terminal at the circuit board. Could be a jumper or miswiring.
Dec 13, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
