Question about Refrigerators
Fisher paykel fridge XRSS264BB not cooling - Refrigerators
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Error code F32 for fisher
All you need to do is, take out 3lt of water from the tab on the fridge without stoping . This will take all the air out from the water tank at theback of the fridge (This will also stop leakage)
Posted on Oct 04, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
My Fisher and Paykel upper refigerator is not working. The lower freezer seems fine. Wha can be done to fix?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 20, 2010 | Fisher and Paykel E522BLXU
Fisher Paykel E522BRX refrigerator not cooling but freezer is working.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 30, 2010 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
