Question about Sony LBT-ZX66i Shelf System
Reset is there a reset button or a way to reset? It wont turn on anymore.
Electrolux Washer front loader got out of balance now wont reset. is there a reset button
There is not a reset button, rather you must unplug or turn the circuit breaker off to the unit for 10-15 minutes. If that does not work, then the drum is not balanced correctly anymore and you need a professional to diagnose it fully.
Aug 22, 2012 | Electrolux Washing Machines
How do I reset the factory car security system after replacing the battery? The parking lights flash and the alarm horn sounds, but the engine wont turn over.
there is a red blinking light it is a reset button just push it and it should cut off. if not the button is bad and you have to go to a junk yard to get it because mitisubishi doesnt stock this part anymore!!!
Nov 01, 2010 | 1999 Mitsubishi Montero Sport
We can turn on the camera, but the OK button does not wok.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 27, 2009 | Kodak EasyShare CX7330 Digital Camera
No power after last cut
I have seen reset buttons not work because they are full of saw dust, Take the cover off the reset button and vacuum or blow it out with compressed air, good luck, cb
May 05, 2009 | Jet 708315LSB 10" Benchtop Tablesaw with...
Wont play dvd
yes there is a rset button u just have to gift me  ur ps3 and ill do it 4 myself best sol 4ever
Jul 21, 2008 | Sony PlayStation Portable (PSP) Console
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
The new ipod nano
depending on when you got it, i think there is a 30 day warranty but phone the store you purchased it at to make sure.
Mp3 player
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Won't come On
Your sister could have held the button in too hard and broke it that's my only answer.
Jan 02, 2008 | RCA OPAL M4001 MP3 Player
It wont turn on
press the reset button on the back
Nov 12, 2007 | Samsung YP-K3 MP3 Player
Sony LBT-ZX66i Shelf System Logo
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
