Question about Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower
Riding mower keeps eating away the shaft and pulley
I hit a old sink faucet in my yard and it broke the spindle so I changed it and then the old shaft and pulley messed up so I bought a new shaft and pulley and it did the same thing it ate the inside of the pulley out and the top of the shaft where the pulley goes so whats my problem?
2 Suggested Answers
bargainbin2
  • 123 Answers
SOURCE: How do I remove the groove pin from the arm on the
You will need a pair of C clip pliers.
Posted on Aug 26, 2009
Replace spindle shaft on 42 insch cutting deck
take the deck off. the shaft you want to replace take the nut off the pulley on top and hit it with a hammer it should fall out the bottom. take blade off and there go. be sure bearings are good put new shaft in and put pulley and washer and nut and blade . take a picture of how it comes apart so you don't forget when you go to put it back together.
Jun 29, 2016 | Garden
Model # 917.289072 19.5 42" When i engage blades it is very noisy like metal on metal It seems to cut ok but I don't want to mess it up more I changed blades and changed oil
Did you check the spindle assembly. I had one that cracked on my mower and had to replace it.It could be broken at one of the corners and this makes the blade spin off balance or not turn at all.Or a pulley could be worn or bent and the belt makes it rotate against the other metal parts.This happened because I hit some stones. They can damage other parts of the mower deck as well as ruin the cutting blades.You can do an online chat with SEARS parts too and their tech may have more info which may hepl diagnose the problem. Good luck,
Jean
May 27, 2015 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 15 year old Moen bathfaucet 4650-P that I want to replace. I can't figure out how to remove this old faucet. It has three holes with the outer holes on 4 inch spacing. The two handles and the...
There is definitly a nut or nuts holding the faucet to the sink. It could be around the center shaft that goes through the sink, but most likely 2 small nuts that screw onto the 2 outer stubs. These are your hot and cold wated supplies. crawl underneath the cabinets and check. It might be difficult to get them off, but they do make a pipe wrench tool that has a rotating head that makes this easier
Mar 04, 2011 | Moen Home
My 6 hp yard machine tiller has a problem when you pull the rope. It has a hard **** or pull back when you pull on the rope. Is the engine out of timing. Thanks JD James It is approx. 4 years old...
sounds like the timing is off.
need to remove the pull cord cover and take the nut off on the shaft and take the cover off and see if the key on the shaft is broke and put a new one on.
when you hit something solid the key will shear.
Jan 26, 2011 | Mtd Products Yard Machines 158CC Tiller
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: FortĀ® Single-control...
Shaft problems
un hook l/h and r/h lift pins from both lift arms , remove front draft arm from front of deck ( it attaches under the muffler on the chassis )
discoonect the blade engage cable from arm if it uses this type or pop the deck belt off the electric pto if the tractor uses this type
you could just spin each spindle without the blade on ( but leave the top pulleys on ) if spindles bent you should see a wobble , if hard seeing it refit both blades and re-spin each spindle and check for quite a noticable variation in blade tracking when each blade is turned through a rev or two
remove deck , remove both mandrell pulleys from the top of thier shafts
remove both blades and use block of wood and knock the blade spindles out of their mandrells from the pulley side
here is website for parts
http://www.outdoordistributors.com/AYP/AYP_Main.html
just click on 917 the select 288280 from the list
it should show parts breakdown
cheers hope it helps
any problems let me know
paul
Aug 01, 2010 | Craftsman Professional 24 hp 42" Yard...
609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Jun 08, 2010 | Mtd Garden
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Trouble removing the faucet from a Delta Waterfall 174
I wouldn't worry about messing up the threads as it is an old unit that you wish to discard. Do what is necessary to hold the threads still with the vise-grips and loosen the nut until you reach the damaged threads. Then pull the faucet up from the top until the nut hits the bottom of the sink and cut the threaded nipple from the faucet with a hack-saw blade. Lay down cardboard to protect the finish of the sink and surrounding counter top.
I have had to do this many times and it usually saves you the headache of bloody knuckles.
Apr 26, 2009 | Delta Faucet Delta 174-SSWF Waterfall...
Hoover U4395 Vacuum fan (impeller) broke
this is a left handed thread
you mite have to hold the other end of the shaft twith a pair of pliers , to un screw it
Feb 06, 2009 | Hoover Vacuums
Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower Logo
21 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
