Question about PSC Magellan 1000i Barcode Scanner - P/N MG10-2010-101-106 Barcode Scanner
The red light on the scanner seems to be on most of the time
Whether we are scanning or not the red lights stay on. If we position the scanner just right it will go off for awhile. If we place a paper sack about 8 inches in front of scanner the light goes out. It doesn't matter where we have the scanner. We have 2 registers and the other scanner doesn't do this.
    Problem Solver:
  • 20 Answers
If you are using magellan 1000i with no button, then it must be your scanner broken. But If you use a button trigger try to push it a while. The Button is on top of the scanner,with a white / light green color.
Posted on Aug 24, 2007
I have a 1999 ford Windstar that seems to get to mush gas & it makes work like garbage & it has no power
There are several types of testing scanners. The cheaper type need an check light to stay on showing check engine light. The more expensive scanners show real time readings whether a check light is on or not. There can be a big assortment of problems that may give the symptoms you show. Have someone check the Vacuum level of the engine.
Jan 30, 2017 | 1999 Ford Windstar
When you power off the unit, it goes from bright led to low light led and shows a red light staying illuminated. Which means its STILL drawing battery. How do you turn it off completely?
Brake Hydraulic System Red Warning Light - RepairPal
repairpal.com/brake-hydraulic-system-red-warning-light
If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Sep 10, 2015 | Cars & Trucks
Scanner has racheting noise and red light stays
This noise is caused by the transport lock. Power the scanner off. Lock and unlock the transport lock a few times and then leave it in the unlocked position again and power on.
Nov 20, 2009 | Epson Perfection 4180 Photo Flatbed...
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
Epson 3490 scanner red light flashing message that printer cannot properly communicate with pc
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
Jul 16, 2008 | Epson Office Equipment & Supplies
Cannon scan 4200f light stays on
There is a lamp shut-off time adjustment in ScanGear. Go into ScanGear's Advance Mode and click Preferences. One of the four tabs will have an option for Lamp Shut-Off time. Set it as desired.
Dec 02, 2007 | Canon CanoScan 4200F Flatbed Scanner
Awful noise
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (the plastic switch at the back of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Oct 16, 2007 | Epson Perfection 4180 Photo Flatbed...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Scanner not scanning
Your 'transportation locks' may have been engaged. (Check lower-left-hand-corner of the inside the scanner cover and the left-back side) See the manual: http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
May 27, 2007 | Epson Perfection 4870 PRO Flatbed Scanner
PSC Magellan 1000i Barcode Scanner - P/N MG10-2010-101-106 Barcode Scanner Logo
349 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
