Question about Maytag MZD2665HE Side by Side Refrigerator
REFRIGERATOR MDL# MZD2665HES
HOW DO I REMOVE THE DOOR HANDLES
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
Tighten door handle on Whirlpool Conquest refrigerator
You need to remove the handle befor eyou can tighten the mounting bolt behind it. T remove the handle just grab it and yank UP quick and hard. The handle will unclip and release, then you can tighten the bolt down and re-install the handle.
How strong do you have to be?!!! Trying that and it won\'t unclip. Not sure how hard to try--or will you break something?!!
You have to pull up pretty darn hard with a jerk. That is how both handles are removed on these conquest refrigerators
Sep 01, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
MZD2665HES
get a skrewdriver (whitch ever it fits ) and turn it counter clock wise
May 07, 2013 | Refrigerators
How do i remove the fridgerator door handle
HOW TO REMOVE DOOR HANDLES (LFX25960
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
1. Removing Refrigerator Handle
Grasp the handle tightly with both hands and slide the handle up (this may require some force).
The keyhole slots on the back of the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble handle, you must push or pull with reasonable force.
2. Removing Freezer Drawer Handle
Press the handle against door first.
Grasp the handle tightly with both hands and slide the handle to right (this may require some force).
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
Apr 29, 2011 | LG LFX25960ST Stainless Steel French Door...
I have a new door to replace the right side one on this refrigerator but for the life of me I can't get the door handle off the old one. New one didn't come w/ the handles/hinges, etc, obviously. The...
Are you sure...
NOTE: Handle appearance may vary from illustrations on this page.
• Grasp the handle tightly with both hands and slide the handle up (1)(this may require some force).
• The keyhole slots (2) on the back of the handle allow the handle to separate from the mounting screws (3).
CAUTION: The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION: When you assemble or disassemble handle, you must push or pull with reasonable force.
Jan 21, 2011 | Refrigerators
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Can't get the refrigerator through the door ; how to remove handl
When I brought my side by side home,I had to remove both doors. I also had to remove the entry door AS WELL as the door center jamb!! Removing the refridgerator doors is really not a major task!
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MZD2665HE Side by Side Refrigerator Logo
51 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
