Question about Olympus EVOLT E-500 Digital Camera
How to replace pins in the cf card slot of an Olympus e500 dslr camera?
Pins broken off, not bent. xd card slot appears to be fine.
3 Suggested Answers
  • 919 Answers
SOURCE: Olympus E10 pins bent on compact flash slot
That is correct. The camera should default and detect that a smartmedia card is now inserted to the camera and write the images to that card. As I stated earlier, the cards are independent of each other.
Posted on Mar 11, 2009
  • 340 Answers
SOURCE: the one pin of my
go to the Olympus service center or repair stores to replace a card slot, it's cheap
Posted on Jul 23, 2011
MY OLYPUS E-500 SAYS CARD ERROE WHEN I TURN ON MY
Did you try to format the card using the camera's software or your computer?
May 20, 2010 | Olympus EVOLT E-500 Digital Camera
As I am scrolling through the pictures on the camera, a "read error"message comes up. This is occuring with all of the memory chips - even the new ones so I do not think it is a chip problem. Can you offer...
you have two slots for memory cards .. one for XD and one for CF .. if you have trouble with one slot then you can try the other type card ..
if you are using a CF card or micro drive .. then look into the slot where they normally go .. look for bent or missing pins .. some CF memory cards don't have much of a "lead in taper" on their connector .. sometimes they will snag a pin and bend it, push it out of place or break it ... sometimes you can straighten it but replacing a broken pin is a big job .. usually the whole connector will be replaced if its sent in for repair .. if you have trouble with the CF slot you can instead use a XD memory card .. or visa versa .. the little LED flashlights are ideal for looking into the memory slot...
make sure you format any new memory cards in the camera before use .. that should pick up any problems and makes sure the card is compatable with the system ..
Jan 25, 2010 | Fuji FinePix S7000 Digital Camera
1 pin bent resulting in "Card Error" message. Attempt to straighten pin broke it off! Camera now appears to work well. What other problems might this missing pin create? Should I keep the camera or replace...
Some of the CF card pins don't do anything. It could be one of those that broke. If, when it was bent, it shorted one of the other pins, that may have caused the "Card Error". Removing the pin may have no negative effect.
Jun 07, 2009 | Olympus EVOLT E-500 Digital Camera
Olympus e520 will not turn on
try to rest your camera and see if that works
Apr 20, 2009 | Olympus E-520 Digital Camera with 14-42mm...
Canon EOS 400D dslr will not work various CF memory cards. Error message ( replace CF card)
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
Apr 02, 2009 | Canon EOS 400D Digital Camera
Mar 11, 2009 | Olympus Camedia E-10 Digital Camera
MY MEMORY CARDS NO LONGER WORK IN MY SONY DSLR A100 CAMERA?
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Jan 12, 2009 | Sony Alpha DSLR-A100 Digital Camera
Olympus E500 card error
check the pins in the cf slot.. should be two even rows and straight... probably needs repair
Dec 13, 2008 | Olympus EVOLT E-500 Digital Camera
Cf card reader sony a 100 dslr
Buy a camera that does not use CF. Time to upgrade.
Nov 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Card error with both cf and xd cards
check the pins in your cf slot.. you may have one bent. either straighten it out or send to repair
Sep 28, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
