Question about True Deli-Cases TSID-48-2-L Refrigerator
Defrost dealing with water when defrosting
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
Where are you getting water that you don't want it I need a little more details so I can help you. Could be a clogged drain tube somewhere.
Posted on Oct 29, 2013
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Inglis refrigerator no water to ice cube tray
Had the same problem once. I'm assuming all of the water connections have been made properly.
Often the water line delivering the water will freeze just inside the freezer. .Pull the unit away from the wall and follow the line into the unit. Use a hair dryer to defrost the line.
Jun 05, 2012 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Fridge not defrosting right water in bottom of freezer then turns to ice.
It sounds like the unit is defrosting, but the drain for the water from the melted ice is plugged. Check that before calling a repairman.
Sep 28, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Got water dripping into fridge from "vent" from
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Can you tell me where my water pan is on my inglis defrosting fridge
There is a water pan or drain pan that holds the defrost water. After a while the heat dissapates the water so it should be dry.
It is located underneath the frig. Remove the grill on the front bottom and with a flashlight you should find it. Its either on the left or the right, since you did not provide the model number.
Mar 30, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Water buildup on the middle rear top shelf of refrigerator
you need to use a turkey baster/ hot water and force it down the drain . this will help . but it will freeze again . so stop bu your appl parts dist and pick up a defrost tube heater kit pt # 819043 . "heat probe .add - on to stop tube ice-ing..) and wa-la your problem is over . make sure the prob is attached to the heater good or it will not trans the heat to the drain properly . mm hope this helped ,mm / feed back pls ..
Feb 03, 2010 | Refrigerators
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Drz 400 sm starts but i cant give it any gas or it dies
Can you slowly increase the revs? It sounds like an accelerator pump or debris in the carb.
Jul 09, 2009 | 2007 Suzuki DR-Z 400 SM
My Inglis Refrigerator doesn't make ice anymore,
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Jun 23, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
True Deli-Cases TSID-48-2-L Refrigerator Logo
79 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
